Ignition Control Module
Old Oct 18, 2014 | 10:51 AM
Trip443's Avatar
Trip443
There has GOT to be a kit out there I can buy to convert my distributor mounted ICM into a remote mounted ICM (Firewall or somewhere else) with a heatsink.
I just bought an ICM and installed one last month, it went up again. This was a BWD brand replacement. I heard I can add washers between the distributor and ICM but I'm skeptical.
Old Oct 18, 2014 | 10:56 AM
rla2005's Avatar
rla2005
Did you use thermal compound on the new ICM? I would not use washers as a spacer. The mounting area on the distributor acts as a heat sink.
Aftermarket ICMs are known to be short lifers...highly recommend a Ford/Motorcraft.
Old Oct 18, 2014 | 10:57 AM
88n94's Avatar
88n94
Did you use the heat sink grease when you installed the BWD ignition control module?
Old Oct 18, 2014 | 10:59 AM
Trip443's Avatar
Trip443
Yes, I did use the dielectric grease that came in the box. I even cleaned both surfaces with alcohol before adding the grease. I know its the same principle as thermal paste on a computer. Unfortunately it still died on me.
Old Oct 18, 2014 | 11:36 AM
88n94's Avatar
88n94
Personally I would take the module back to where you bought it, it should have a warranty. You may have just got a bad one.
Years ago I installed a G P Sorenson ignition module on my "88 f-150 and it is still going. I went to Advance Auto Parts to buy a spare module for my "90 Taurus and requested a G P Sorenson, The Parts guy told me they changed the name to BWD, I assume it's true because on the both boxes there is a sticker that says "assembled in Hong Kong."
Also there was a post a short time ago(maybe on another site) asking about the quality of BWD products, I think everybody thought they were decent quality. Well, good luck whatever you decide to do.
Old Oct 18, 2014 | 11:50 AM
subford's Avatar
subford
Dielectric grease will not work, it has to be white thermal compound for the heat transfer.
The Dielectric grease was for the pins.
Old Oct 18, 2014 | 12:56 PM
Trip443's Avatar
Trip443
interesting, this is what was included though. (it looked like semi transparent goop)
I was thinking of putting Arctic Silver 5 but I'm not sure what conditions the AS5 would endure under the hood.
I was thinking the same thing. I have asked around about BWD and the general consensus is that they are a good replacement brand.
Old Oct 18, 2014 | 02:16 PM
rla2005's Avatar
rla2005
Normally I would agree BWD is a decent brand but when it comes to ICMs I highly suggest OEM.
Old Oct 18, 2014 | 04:31 PM
Trip443's Avatar
Trip443
I suppose you are right. It was hard to turn down a BWD brand ICM when it only coated me 25 bucks. When compared to a Motorcraft brand ICM at around 120 bones. I suppose its one of those times where I should have just gone with the real deal once .
abyars111
Apr 29, 2013 03:09 PM
ol'bluef150
23
Mar 25, 2010 10:37 AM
javi2001
Jun 25, 2007 06:57 PM
NJbronco138
1978 - 1996 Big Bronco
May 11, 2003 10:34 AM
TryMe
Apr 17, 2003 02:16 AM
