Lights dim with fan on
Only at night, or whenever the headlights are on, and I turn on AC/Heat or just vent, the volt gauge will creep towards the left. In D or R it will go all the way to the N where normally it sits on A. If I turn the fan or AC off it jumps right back to A. Did these trucks just come with low amp alts? would it be worth it to upgrade to a 200a-300a aftermarket one? I just gotten used to it. On freeway or driving the gauge and lights are fine but when stopped I just turn fan to low. Again only with headlights on.
Thanks '92 F-250 in Sig
Since the same OP did not state they had issues with battery charging, slow/hard starting, etc. I feel confident they are experiencing the symptoms of a poor alternator design.
I'm having the same symptoms as the OP,in my 93 F-250 with the 5.8. except I have slow hard starting, most of the time. Only sometimes will the truck not have a slow hard start.
The starter barely cranks, like the battery is dead. but if I keep the key turned it will eventually fire up.
What is the likely cause of my problem?
I have a new alternator. I bought a new one not long ago, but it was apparently bad, so Oreillys warrentied it and tested the new one before they gave it to me, but I am still having the same problem.
hermancm
07-10-2017 08:43 PM
RMS94
01-26-2007 10:29 AM
bob-63-292
03-08-2004 11:49 AM
