High Idle help
Old Oct 11, 2014 | 11:45 AM
KDAVID1's Avatar
KDAVID1
High Idle help
The 4 wires in the middle of the pic that are wrapped on the ends are the wires I need to be working with correct? I'm using the diesel stop post but can't get the pics.
Old Oct 11, 2014 | 12:19 PM
KDAVID1's Avatar
KDAVID1
OK so I found the uplifter wires and assumed the ones in the pic are correct. Got them hooked together--solid orange to orange/light blue--started truck, flipped #4 lifter and nothing--I'm stumped.
Old Oct 11, 2014 | 12:20 PM
KDAVID1's Avatar
KDAVID1
I think I figured it out
Old Oct 11, 2014 | 01:03 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
What was the issue?
Josh
Old Oct 11, 2014 | 01:21 PM
KDAVID1's Avatar
KDAVID1
Originally Posted by Bullitt390
What was the issue?
Josh
Up and running--it's a beautiful thing
Reading the diesel stop site I was a little confused and had the solid or and and orange/light blue swapped ie: right color wrong bundle. I kept colors and swapped bundles and good to go. I'll write up an explication with pics a bit later for any others that may get confused.
Old Oct 11, 2014 | 03:39 PM
KDAVID1's Avatar
KDAVID1
Using the Diesel stop site for the high idle mod for 2005-2006 I was a little confused as to the wires to hook up. What I found out (at least for me) it was easy to pick the correct wires but not the correct harness (It could just be me) So for those like myself here you go.
The SEIC solid orange wire is not the orange wire in the bundle that is ALL orange wires with different strips but is the one in the bundle furthest back under the dash and amongst many different colored wires. Note there is a wire that is orange with red stripe that looks like solid orange.
SEIC wire--bundle may or may not have the label tag
Now for the uplifter switch these wires are in the bundle closest to the dash and is where you would pick the orange and light blue wire (for #4 switch) These wires are the open wires closest to the main RED bundle that connects to the fuse box.
Uplifter switch wires
Hope this is helpful to someone--I know it took me two tries to get it right lol
Mike
Old Oct 12, 2014 | 05:11 PM
Yahiko's Avatar
Yahiko
Mike
Have you had muddy water up under there ? That last photo
looks like it got a bit dirty.
Sean
Old Oct 12, 2014 | 06:25 PM
KDAVID1's Avatar
KDAVID1
That was actually from me. It rained and tthe yard was a little muddy
2006 F350 4X4
Old Oct 12, 2014 | 08:54 PM
Yahiko's Avatar
Yahiko
2006 F350 4X4
Better that then going swimming I think.
Sean
Old Oct 12, 2014 | 09:29 PM
KDAVID1's Avatar
KDAVID1
Sean
Got that right. Had to do it once or twice in a early model Bronco lol
2006 F350 4X4
Turbo Dog
Nov 11, 2017 06:08 PM
maltesecross
6.7L Power Stroke Diesel
Jan 13, 2013 09:34 PM
drizzie27
Mar 28, 2012 06:08 PM
hedhntr
13
Jul 22, 2010 12:49 AM
mrchip1958
Apr 24, 2010 07:07 AM
