Tire size & Shift Points
Old Oct 13, 2014 | 02:50 PM
Pocket's Avatar
Pocket
Originally Posted by Mark Kovalsky
They both come from the VSS.
There is a computer (I don't know which one) that converts this to MPH for the speedometer to display. Separately the PCM reads the VSS to determine axle speed. Changing what the speedo sees DOES NOT change what the PCM sees.
OK that was my next question.
My understanding of this has always been that it was speed related when it comes to transmission shift points, but it didn't occur to me that the VSS signal is split between the ABS module (speedo calibration) and PCM (trans shift strategy).
So on a side note that now gives me a new idea for something to check out in the tuning.
I guess hard headed folks like me can take a lernin' to new stuff every now and then. For some reason my head wouldn't wrap around what was happening until I knew where the signal itself was going, and I just had to take a step back and start over again to have it explained where I would understand. Thanks for the explanation and having patience with me. Not sure why I couldn't figure it out but now it makes sense.
Old Oct 15, 2014 | 02:16 AM
retiredsparky's Avatar
retiredsparky
Thank you Mark for explaining this - it is actually making sense now. Sometimes we get a certain idea and it can be difficult to understand what the actual sequence or logic is when it comes to these "simple" diesels. It makes me really like the old hit and miss engines and the diesel powered pile drivers where the ram is just a giant diesel powered piston. No brains needed to understand how they work.
Old Dec 22, 2017 | 03:37 PM
The Brad's Avatar
The Brad
Sorry to dredge up an old thread, but I’ve been talking to Akcooper in here and comparing AutoEnginuity to Forscan as it pertains to correcting tire size. It appears that AE changes the tone ring size while Forscan changes the revs per mile. Akcooper has been in contact with Forscan and they’re working on a version that’ll change the tone ring and/or rev per mile. After correcting for my 35s in AE, I found that Forscan displayed an error in my as built data because Forscan was expecting to see 120 tooth tone ring, but AE had reprogrammed it to 111 teeth. This is more of an FYI, but with the back and forth about axle speed vs. vehicle speed, I would imagine that revs per mile has no effect on shifting, but changing the tooth count on the tone ring would.
Old Dec 22, 2017 | 09:58 PM
akcooper9's Avatar
akcooper9
Good questions. Anyone have any thoughts on this?
Old Dec 25, 2017 | 07:29 PM
akcooper9's Avatar
akcooper9
Here is a screen shot of the beta verson of FORscan that lets you adjust the Revs Per Mile or the Tone Ring value. As you can see, my Rev Per Mile is adjusted for my 35s
Old Dec 25, 2017 | 08:32 PM
RigCity's Avatar
RigCity
How do I get that forescan setup to change tire size? A mechanic replaced my PCM 2 years ago and didn’t reprogram the tire size. The truck drives fine justness annoying for me and the speedo. Found out he didn’t reprogram the hard way when I got pulled over going 77 while having the needle at 70 Thanks
Old Dec 26, 2017 | 06:46 AM
akcooper9's Avatar
akcooper9
A PCM change wouldnt not affect your speedometer as the values are that calculate speed are stored in the ABS.
The public version doesn't support this yet unless you know how to edit hex values.
Old Mar 5, 2019 | 08:51 PM
Josh Hein's Avatar
Josh Hein
Do you want it to shift earlier or later? I don't understand why changing tire size would cause a change in when it shifts.
Either way the only way to change it is with software.
Hi mark
I have a question I had 4.88 put in front and rear and now when I hit 75 on the speedometer my truck starts jerking and such . Feels like maybe I hit the speed limiter early unsure what's going on with it didnt have this problem with the 3.73 speedometer is only 5mph off by gps on my phone
Old Mar 6, 2019 | 12:40 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Only speed limiter on my 2002 is my fear of worn out S rated tires blowing up. You have a commercial/gov't rig? What year?
Could be you simply have a tire or 4 out of balance. With 3.73's that might show at 85 mph, but now it's showing at 75. Recommend you post up more info on your own thread so it will attract more eyeballs.
Still I'd get that speedo recalibrated. With it off like that you have no way to argue with a speeding ticket.
Old Mar 6, 2019 | 09:00 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by Josh Hein
Hi mark
Driveshaft speed.
​​​​​​​Yes, it's monitored and the PCM cares about it. However, you should be able to do at least 90 MPH (3200 RPM in overdrive with 4.88s with any tire taller than 33") before the driveshaft speed gets to that speed. Tell me your PCM code or current calibration hex code and I'll look up the factory speed when I get home from work.
USUALLY the speed limiter doesn't create a jerking sensation though. Power output simply tapers off before the max speed limit and acceleration just stops.
Old Mar 6, 2019 | 06:26 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Nevermind.
I got home and looked at your other 5 posts on FTE and see that you have a 5.4L.
What I said probably doesn't apply.
dmitrysgarage
Oct 9, 2020 09:53 PM
schmiddw
13
Mar 10, 2019 09:04 PM
49fordfiretruck
Jul 13, 2010 01:44 PM
waynedavis
Computer Chips & Tuners
Feb 8, 2007 11:00 AM
cokeman
Jan 12, 2004 05:37 PM
