I appreciate the effort folks. Yes, I have read the "sticky"...I understand the importance. My question is more about the finer details of how it get s done
I was prompting those who have already plumbed coolant to the under side of their Offy "C" series intake and hopefully show or discribe where the porting is placed....in the shallow end (outward )or the deeper end ( nearer the engine).
I chatted with Offenhauser and they were not very receptive to the idea of plumbing coolant there.
Reason: better info
Offenhauser's attitude might be because the manifold was designed to work with the stock log exhaust manifold. But most of the folks are using EFI exhaust manifolds and some use headers and neither have the necessary configuration to hook up like the stock exhaust manifold does.
The plumbing is easy with a plate to cover the cavity that is plumbed with two hose fittings...water in, water out and it works by splicing it inline with one of the heater hoses...really quite simple.
and from the few Pictures on the last page....most seem to run the porting left to right (orientating to the engine) ...so that makes one port to the deeper side of the intake and one to the shallower side.
Some of my dilemma was what size to use 1/2" or 3/8"?? looks like 3/8" is the choice?
My intention is to use a 1" thick alum block ( leftovers from work)...& maybe make a sightly deeper cavity and perhapes better cooling compassity. With the thicker block then affords the ability to machine porting on the side and eliminate the need for the 90 degree elbows
The plate I made is 3/4 inch plate aluminum. Had to grind some of it off in the back near the number 3 " i think it was three" header pipe for clearance. Worked fine with my hedman headers.
