77F350 clutch replacement
Old Oct 9, 2014 | 08:20 PM
baumer70's Avatar
baumer70
77 f350 with a 351m soon to be 400 engine. borg warner t18 tranny. had clutch problems today it wont release when you push on the clutch pedal so I started it in gear and drove it home through the country. im looking for a clutch kit and was wondering if anyone could offer any advise/suggestions?
Old Oct 10, 2014 | 01:20 AM
privateer, eh's Avatar
privateer, eh
You may have broken a clutch finger, it's happened to me many many years ago in a 75 ford van. Luk clutches have always worked for me in light duty trucks. Thats anything that doesnt pull a bobcat or have a dump or cargo box on it. Centerforce or Mccloed shaeffer if your working it.
Old Oct 10, 2014 | 11:09 AM
baumer70's Avatar
baumer70
Thanks a lot! Im gonna pull it tomorrow and see what the trouble is. figured id go ahead and put a kit in it regardless. what a great forum you all have here. im excited to be a part of it.
Old Oct 10, 2014 | 11:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Seems to me that the problemo may involve more than just the clutch disc/pressure plate...if it pertains to these parts at all.
3 truck parts catalog pics: Left upper & lower / Right upper.
Old Oct 10, 2014 | 08:51 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
The 400 uses a 12" clutch and the 351m uses a 11"
D7TZ-6375-D .. 400 Flywheel-with 12" clutch.
D7TZ-6375-E .. 351M Flywheel-with 11" clutch.
Old Oct 10, 2014 | 09:48 PM
baumer70's Avatar
baumer70
thanks for the breakdowns numbers dummy. I wasn't thinking linkage issues just because the pedal feels fairly normal. ill find out if I get it pulled out this week. Im gonna try and print those though they will more than likely come in handy. I plan on building this truck as my wallet allows. I want a good solid dependable workhorse when im done. Be able to drive cross country without worry and still get off the road and root in the mud when I feel the need. A 400 crank and pistons, 600cfm carb, aluminum intake and 2 bbl heads, Decent headers and exhaust should get me at least 325hp. Axle lockers seem to be a must have as I wasn't real impressed with it in the mud.(I thought I got stuck way too easy!) I work on mining machinery in an underground coal mine so im hoping with the help of this forum and my mechanical experience I can build a rock solid workhorse.
Old Oct 10, 2014 | 09:51 PM
baumer70's Avatar
baumer70
would I be better off changing to a 400 flywheel?
Old Oct 10, 2014 | 11:50 PM
77&79F250's Avatar
77&79F250
Well maybe this will come in handy also?
HMB_Superduty
13
Jul 25, 2015 05:54 AM
Pwnm30rdi3
Jun 6, 2012 06:05 AM
70torino429
Jul 4, 2010 05:21 PM
bigrig410
Feb 10, 2009 11:37 AM
fixnmyf150
Apr 7, 2004 02:45 PM
