Power steering pump
Dec 20, 2014 | 04:03 AM
Power steering pump
Hi all got a 54 f100 with a 1964 ford 289 v8 does anyone have any pictures on how the power steering pump mounts??
Dec 20, 2014 | 10:20 AM
Quote:
Originally Posted by
54truck
Left: 1963/64 Falcon/Fairlane, 1965 Mustang before 8/23/64 came with the Eaton P/S pump that has the separate reservoir mounted to the top of it.
Is this what you have?
Right: Or do you have the 1965/66 Ford pump (1967/77 similar) with the steel reservoir made as part of it?
Dec 20, 2014 | 10:26 AM
NumberDummy
1964 came with the Eaton P/S pump that has the separate reservoir mounted to the top of it.
Is this what you have...or do you have a 1965 (1965/77) Ford pump with the steel reservoir made as part of it?
Hi it's ford pump with the steel reservoir made part of it.
Dec 20, 2014 | 07:22 PM
Left: This isn't a very good pic of the P/S pump mounting bracket (3A732), but this is all I could find for 1965 289.
Right: Better pic showing two P/S mounting brackets (3C511 & 3A732).
Dec 21, 2014 | 07:00 AM
Found this on the WEB. Mounting is different if you also have A/C.
Dec 22, 2014 | 04:30 PM
Thanks for the pictures at least I can see how it mounts. Does anyone know how to tension the belt up?? Once it's bolted in place? Cheers
Dec 22, 2014 | 07:05 PM
I believe the bolt that's partially covered by the pully on the bottom is slotted.
Dec 23, 2014 | 06:38 AM
Loosen the top mounting bolt and the bolt below it that is covered by the pulley.... CAREFULLY use a prybar between the mounting bracket and the front of the pump housing to pry some tension on the belt. Be careful not to dent the pump housing/res
Also, when you intall the water pump bots, make sure you put sealant on the threads
Dec 23, 2014 | 03:58 PM
Hi thanks for the replies my mounting bracket at the bottom doesn't have a slot in it to move it. Just a hole to bolt it still.
Order and Chaos
Oct 1, 2016 10:58 PM
Tony_C
Jan 16, 2012 01:40 AM
FordF100man
Jan 24, 2008 09:35 PM
Trail_Rider
Apr 23, 2000 09:48 PM
400HP794x4
Apr 23, 2000 09:41 PM
