Power steering pump question
Old Jan 24, 2008 | 08:42 PM
FordF100man's Avatar
FordF100man
I have a brand new power steering pump for and 80s, ford mustang 5.0 and i was woundering if the power steering pump that came out of a mustang are the same as the one thats in my 88 F250 with a 351 W.
Thanks
Old Jan 24, 2008 | 09:05 PM
RC Dan's Avatar
RC Dan
I think some of the older 351s came with the Saginaw style pump. The Mustang one you have is a Ford, plastic reservoir, pump. They are known to be a little noisy at times.
If the one in your truck is the Saginaw pump, it will have a steel reservoir. If that is what your truck has, they wont interchange without using a newer pump mounting bracket.
Old Jan 24, 2008 | 09:35 PM
brown 4x4's Avatar
brown 4x4
Saginaw pumps were in vans only. Both the Mustang and F-250 should have a plastic reservoir pump. They should be the same but it would be best to compare mounting holes and fittings to be sure.
