Battery/Alternator Tester
Old Oct 5, 2014 | 03:13 PM
fusefinder's Avatar
fusefinder
Does anyone have a favorite Battery /Charging System tester that they use and feel is reliable. Besides this truck I have a small fleet of vehicles, (1 SUV, 4 Cars, 2 Bikes, and other power equipment) I would like to have a reliable battery load and alternator charge, test meter. Also would like it to be affordable...not too much to ask right?
Thanks!
Old Oct 6, 2014 | 07:47 PM
sgarder's Avatar
sgarder
I think the first step is a digital multimeter. I currently have a couple of harbor freight and fluke meters available to me. Both have been accurate. As far as a load tester I am sorry I am unable to help you. I have access to a snap on unit through work and really have not used any others. Sorry.
Old Oct 6, 2014 | 09:51 PM
Tedster9's Avatar
Tedster9
Sounds like what you want is a battery conductance tester.
Midtronics (there are others) makes an entry level model for about a C note. Since you have quite a few to service and monitor it would be a good tool to have. Also handy if you ever decide to help someone stranded needing a jump or diagnosing a "new" vehicle problem. The standard method of testing a battery correctly is time consuming because it requires fully charging the battery then partially discharging into a carbon pile, and recharging again.
Conductance testing is a newer method utilizing a derived AC signal and gives accurate battery health in seconds and doesn't require charging before or after the test. They also have a volt display for charging system use. No sense messing around with a defective battery, so it pays for itself eventually.
Old Oct 7, 2014 | 02:53 PM
tjc transport's Avatar
tjc transport
i ain't rite
Old Oct 7, 2014 | 03:01 PM
white Buffalo's Avatar
white Buffalo
I use the second one TJC Transport posted and a multimeter.
Old Oct 7, 2014 | 03:26 PM
Tedster9's Avatar
Tedster9
Well, a $5 HF voltmeter will work too, if one knows what they are looking for. It's all good as far as that goes.
Old Oct 8, 2014 | 07:51 PM
whitetmw's Avatar
whitetmw
We have a D-Tac Elite in the shop. But, $4k is probably not what you're looking for.
I have a SOLAR BA5 100-1200 Cold Cranking Amps Electronic Battery Tester for road calls. Which, surprising to me works well for $40 - $70. I bought one for home as well.
The Carbon Pile Testers can be cumbersome and a pain sometimes with the short leads.
SBV45
2009 - 2014 F150
Jan 6, 2022 06:36 PM
Bills68F250
Sep 28, 2016 11:04 AM
FireFighter4Life
Jan 1, 2011 02:04 PM
msully005
1983 - 2012 Ranger & B-Series
Dec 21, 2007 06:43 PM
mooktank
Nov 11, 2002 03:18 PM
