Tps problem?
Old Oct 1, 2014 | 01:00 PM
jeffh1966's Avatar
jeffh1966
Tps problem?
I have a 1987 f250 4x4 with a 302efi 4spd. Motor starts and runs fine. When you start driving and accelerator peddle is pushed about a quarter of the way down motor will start to stumble and return to idle. I have replaced fuel pump in tank and fuel filters. Engine is not showing any codes. Is this a throttle position sensor problem? If it was I would think engine light would come on.
Old Oct 1, 2014 | 01:51 PM
carguy94's Avatar
carguy94
how are you reading the codes. how long has this been going on will it stumble when in park or neutral and did you check fuel pressure. do you have dual tanks. if you checked fuel pressure did you use a jumper and the EEC test connector
Old Oct 1, 2014 | 04:12 PM
jeffh1966's Avatar
jeffh1966
I am using a sunpro by actron code scanner. This started about 2 weeks ago. When it starts to stumble if you push in the clutch it runs fine. Truck does have dual tanks but I only use the front one because of a hole in the rear tank. I have not checked fuel pressure.
Old Oct 1, 2014 | 04:29 PM
rla2005's Avatar
rla2005
That fancy code scanner should report System Pass code 11 if there are no errors in the KOER tests and no stored codes. Anything less means your code check is invalid.
Old Oct 1, 2014 | 07:49 PM
carguy94's Avatar
carguy94
does your MIL work and I guess a stick don't have park sorry about that one.
vintagequest
May 16, 2018 05:11 PM
6stringcowboy
33
Aug 15, 2017 09:52 PM
moose60
Oct 22, 2014 02:44 PM
Smokey1961
Jan 17, 2009 04:05 PM
1996F250
Jan 15, 2007 03:06 PM
