Bucking E150 Van
Old Jan 11, 2009 | 12:09 AM
Smokey1961's Avatar
Smokey1961
Bucking E150 Van
I have an 86 E150 van with the 5.0 It is giving me fits. It is bucking like a vapor locking carbed motor. I have changed both fuel filters, the can type one and the tuna can type.
Checked fuel pressure and it is 37 lbs + driving and steady, rises with acceleration, pops right to 40 lbs. when key is turned on. Both tanks are full.
I hooked pressure gauge up to port and took for a drive and when it starts bucking the pressure remains steady at 35-40lbs. I pulled the codes out and they are below.
I never knew how to do this until I used the search and found out how and where the link for the codes were. I am unable to find these symptoms though. I am wondering if I am chasing a fuel problem and it is something else. It is not plug wires or plugs, the engine just flat tries to die and if I slip it into neutral it will idle and rev up but goes to bucking as soon as I put it back in gear (auto trans)
Any thoughts would be appreciated.
Thanks, Jeff
Code 31...
<TABLE style="FONT-SIZE: 100%" cellSpacing=0 cellPadding=2 border=1 table><TBODY><TR><TD><CENTER>X</CENTER></TD><TD></TD><TD><CENTER>X</CENTER></TD><TD>PFE or EVP circuit below minimum voltage of 0.24 volts.</TD></TR></TBODY></TABLE>
Code 63 <TABLE style="FONT-SIZE: 100%" cellSpacing=0 cellPadding=2 border=1 table><TBODY><TR><TD><CENTER>X</CENTER></TD><TD></TD><TD></TD><TD>TPS circuit below minimum 0.6 volts.</TD></TR></TBODY></TABLE>
Code 81 <TABLE style="FONT-SIZE: 100%" cellSpacing=0 cellPadding=2 border=1 table><TBODY><TR><TD><CENTER>X</CENTER></TD><TD></TD><TD></TD><TD>Air management 2 circuit failure (AM2/TAD).</TD></TR></TBODY></TABLE>
Code 82 <TABLE style="FONT-SIZE: 100%" cellSpacing=0 cellPadding=2 border=1 table><TBODY><TR><TD></TD><TD><CENTER>X</CENTER></TD><TD>Air management 1 circuit failure (AM1/TAB) .</TD></TR></TBODY></TABLE>
Old Jan 11, 2009 | 10:07 AM
Smokey1961's Avatar
Smokey1961
Can a fuel pump be bad and still pump pressure but not fuel?
Thanks, Jeff
Old Jan 11, 2009 | 12:30 PM
Franklin2's Avatar
Franklin2
Those are the codes that came up? The throttle position sensor would make it buck and jerk. If you have a lot of codes that say many sensors are "below minimum", that could point to a wiring problem, since many sensors failing at once is unusual.
Old Jan 11, 2009 | 01:47 PM
Smokey1961's Avatar
Smokey1961
Thank you for your post! Yes those are the codes that came up, I did them three times. So could I assume that more than likely it may be a grounding issue? I am going out to hook up my timing light and see if I still have spark when this happens. I am also going to go over the grounds and look closely at the wiring.
I have pretty well convinced myself that it is not fuel, as it does it on either tank with no changes at all and pressure is good. Any more ideas, I'm alll eyes.
Thanks, Jeff
Old Jan 11, 2009 | 05:19 PM
Smokey1961's Avatar
Smokey1961
Ok here is what I have found out today. I have to drive it at least 25 miles or so before it starts bucking. I have already determined that fuel pressure remains constant when this happens. I hooked my timing light up to it while driving and when the engine loses power there is still spark going on as the timing light doesn't miss a beat.
If I hold the throttle steady when the engine loses power and shift it to neutral (auto trans) the motor revs up instantly. As soon as I put it in gear it loses all power again. I can do this and it will do it every time when it starts bucking. When in gear after shifting from neutral it makes no difference where the footfeet is no power, but as soon as I go to neutral it comes to life. I done this several times and it was something that I could repeat every time. Hope someone can give me some things to check out now.
Thanks, Jeff
Old Jan 11, 2009 | 05:53 PM
pfogle's Avatar
pfogle
Ok, replace the TPS it's likely bad. This will probably cure it. The TAB and TAD (Themactor Air Bypass/Diverter) codes mean the solenoids didn't respond. They don't do anything important on that year of van anyways. The TPS seems like the culprit to me.
Old Jan 11, 2009 | 06:00 PM
Smokey1961's Avatar
Smokey1961
Thanks! The TPS was somewhat suggested before. I was hoping this new info would shed more light on the problem. Now to go see how much a TPS is before I change it.
Thanks, Jeff
Old Jan 11, 2009 | 11:23 PM
Franklin2's Avatar
Franklin2
Get the computer happy with a code 11 or like was said codes that are not important, before continuing.
Old Jan 17, 2009 | 03:05 PM
Smokey1961's Avatar
Smokey1961
Follow up on my dilema,
Problem Solved!
Thank you all for the help! It is truly appraciated!
After checking all kinds of wires and ground connections I bit the bullet and bought a TPS Sensor and put it on today. Van runs like a top again and no bucking at all.
Thanks again guys!!
Jeff
Old Jan 17, 2009 | 03:11 PM
Freaksh0w's Avatar
Freaksh0w
I swear, I was just going to recommend going ahead and getting a new TPS. My 86 5.0 EFI did the same thing. Did you clean the throttle body out real good while you had it disconnected from the intake? Mine was FULL of crud.
Old Jan 17, 2009 | 04:05 PM
Smokey1961's Avatar
Smokey1961
Yes I did clean it out, it was real bad. Blew cleaner through the vacuum ports on the body also. It is clean as a whistle now and running good!
Jeff
megawatt00
52
Sep 25, 2012 06:01 PM
Sheryle
Nov 27, 2011 11:04 PM
pjnadon
Jan 18, 2011 09:31 PM
myutesux
May 6, 2010 07:33 PM
Meatco1
Mar 3, 2008 07:54 PM
