This damn 7.3
Old 10-01-2014, 07:19 AM
Bandito1's Avatar
Bandito1
Bandito1 is offline
This damn 7.3
this damn 7.3
Yesterday 08:15 PM by Bandito1
Ok I have replaced almost every sensor, filter, so on... To get this beast running. I refuse to give up and thank god for fat pockets right now. I have spent in the neighborhood of $3000.00 since the "break down" and that was pretty much running out of fuel. Found oil to be low and so i changed it and the filter as well. This baby is a 2000 f-250 7.3. Parts replaced....icp, icm, pcm, cps, batterys, starter, fuel filter, gpr,.... Any help would be apperciated. Oh and since the new pcm no codes. I can get the truck to run with a bump of either and 1/4 throttle, and keep it running for quite some time , but when i let off of throttle it dies. It dies at about 1400 rpm
Old 10-01-2014, 07:33 AM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
What are you using to check codes. do you have a scan tool. Time to look at sensors and see what is broken. No need to throw any more parts at it. Cost too much to try to fix it that way.
Old 10-01-2014, 07:41 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
that repair bill, will get get significantly higher if you keep up with the ether.
like mentioned, need hooked up to AE or similar
Old 10-01-2014, 07:48 AM
Bandito1's Avatar
Bandito1
Bandito1 is offline
Elite auto scanner. And i know about the either thats why its just a bump of it and ive only done it twice. Hope that doesnt kill it.
Old 10-01-2014, 07:51 AM
Tugly's Avatar
Tugly
Tugly is offline
The last link in my signature will show the key ingredients for start and idle - if you have a scan tool. Your device looks to be a code reader and nothing more - please correct me if I'm wrong.
Blind Buck$Zooka blasts: $3000.00
Scan tool (like AE Ford Enhanced) for now and the future (if you already have a laptop/netbook) $370.
OBDII scan gauge - anywhere from $100 on-the-cheap to $400 for the mondo deluxe.
Old 10-01-2014, 08:28 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
Where in The Great State of Texas are you located?
Old 10-01-2014, 09:06 AM
AllaboutMPG
You may have one side not firing. Use a meter to check the injectors for continuity. the linked print and pic of plug will show you what to ohm out.
https://www.ford-trucks.com/forums/1...-material.html
Old 10-01-2014, 09:44 AM
Bandito1's Avatar
Bandito1
Bandito1 is offline
Amarillo tehas ,and ill check continuity tonight.Any other suggestions would be greatly appreciated...😁
Old 10-01-2014, 07:33 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
If your truck will only start with ether, you need to be looking at compression numbers. Until you do that, don't put another dime into it my fellow Texan.
Old 10-01-2014, 08:32 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
It could be compression, but I'd lean more toward it being a low ICP issue, at least initially. Either IPR, a major internal leak, or weak HPOP. A scan tool would probably be very beneficial.
Old 10-02-2014, 06:24 AM
cschulz135's Avatar
cschulz135
cschulz135 is offline
You said original problem was low oil. What about the fuel? Is your tank 1/2 full or more? If the foot valve in the tank came off (very common) will run out of fuel around 1/4 tank. Or possibly when it was ran low, crap made its way into the in tank screens (also common). Good time for the Hutch and Harpoon mods if you haven't done them already. Failing this, I would look at the IPR valve real hard. The symptoms sound like a stuck IPR, will start on ether but then die. Bad battery cables will allow the engine to spin, but not have enough voltage to fire the injectors.
Old 10-05-2014, 02:13 PM
Bandito1's Avatar
Bandito1
Bandito1 is offline
Truck is throwing up a p1212 code. I am sending it to a mechanic monday morning just thought id ask if anyone knew what the problem was.
Old 10-05-2014, 05:39 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Sound like it isn't building enough hydraulic pressure (ICP) to start. Could be stuck IPR, high pressure oil leak, or even a bad HPOP.
Old 10-05-2014, 06:03 PM
Bandito1's Avatar
Bandito1
Bandito1 is offline
Just baught a brand new ipr about to install it now. Also have obd11 scanner that i know absolutly nothing about.
Old 10-05-2014, 06:05 PM
Bandito1's Avatar
Bandito1
Bandito1 is offline
Except for the fact that i can get it to read codes thats about it
Quick Reply: This damn 7.3
