Virginia Chapter Join Chapter, Leader:
VA's October Chat thread!
Old Oct 7, 2014 | 09:59 AM
  #181
camper415's Avatar
camper415
good morning yall , I get to leave my truck at the local ford dealer today so they can rotate my tires align my truck and balance my tires to try to alleviate the death wobble I am experiencing . They claim all front end parts are tight and in tolerance .
Old Oct 7, 2014 | 10:23 AM
  #182
archtaan's Avatar
archtaan
Good morning Virginia
Old Oct 7, 2014 | 10:32 AM
  #183
67nukeford's Avatar
67nukeford
Veteran: Navy
Morning Tom, Tim! Tom, had the same problem, I lost a wheel weight on the left front. had a pretty good vibration up around 70 mph.
Old Oct 7, 2014 | 11:06 AM
  #184
camper415's Avatar
camper415
no this is hit a bump just right at over 50mph and the truck violently shakes from side to side until you slow down to 15 or so and it gets back to normal . the pucker factor is not good.
Old Oct 7, 2014 | 11:09 AM
  #185
67nukeford's Avatar
67nukeford
Veteran: Navy
Oh, that wobble. I thought they fixed that. You don't have it lifted, do you? I heard somewhere that puting a lift on it can cause that.
Old Oct 7, 2014 | 11:10 AM
  #186
GLR's Avatar
GLR
Sounds like loose parts somewhere, Tom. That or tire balance.
Old Oct 7, 2014 | 11:12 AM
  #187
67nukeford's Avatar
67nukeford
Veteran: Navy
Do you think tire balance would cause that, George? Sounds like something worn out/loose.
Old Oct 7, 2014 | 11:16 AM
  #188
camper415's Avatar
camper415
I had it in for that and they told me there were no worn or loose parts and they wanted to rotate the tires balance etc. but had to set up an appt. so this afternoon I will drop it off and drive a rental to work. ugh!
Old Oct 7, 2014 | 11:18 AM
  #189
67nukeford's Avatar
67nukeford
Veteran: Navy
Well, hopefully they can figure something out, that's too damn dangerous to drive it like that!
Old Oct 7, 2014 | 11:24 AM
  #190
GLR's Avatar
GLR
I've run across unbalanced wheels start the worn parts moving. Won't stop until you slow down.
Old Oct 7, 2014 | 11:26 AM
  #191
camper415's Avatar
camper415
Oh and no my truck is not lifted , it has the 20 " option from the factory with the original Michelin 275/65r20 tires . I have 39000 miles on my truck so hopefully it is not a tire issue as they are pricey.
Old Oct 7, 2014 | 11:27 AM
  #192
GLR's Avatar
GLR
Now I'm thinking possible broken belt in a tire....
Old Oct 7, 2014 | 11:31 AM
  #193
camper415's Avatar
camper415
That is one of the things they said it could be . oh well its only money . shame I don't have any.
Old Oct 7, 2014 | 11:35 AM
  #194
archtaan's Avatar
archtaan
Tires are so expensive. Is it under warranty?
Old Oct 7, 2014 | 11:37 AM
  #195
camper415's Avatar
camper415
I bought an extended warranty when I got the truck last year.
