272 HD
Old Sep 30, 2014 | 11:51 AM
haven56's Avatar
haven56
272 HD
Would a 1956 272 HD motor bolt up to a 56 3-speed LD transmission without any modifications?
Old Sep 30, 2014 | 03:42 PM
charliemccraney's Avatar
charliemccraney
Many Y-Block parts are interchangeable so the short answer is yes.
What is it, exactly, that you are trying to do? Swapping from what, to what?
Old Sep 30, 2014 | 04:55 PM
haven56's Avatar
haven56
I currently have a 1963 292 hooked up to the 3 speed trans. I might be able to get the 56 272 heavy duty motor as a backup. Just wondering if it would bolt up.
Old Oct 1, 2014 | 03:31 PM
charliemccraney
Yes, that should be pretty easy. There might be small things like the front motor mount bracket that will have to be swapped or carb linkage but for the most part, it should bolt in easily.
Old Oct 1, 2014 | 04:24 PM
haven56's Avatar
haven56
Ok. Sounds good, thanks.
robert leagh
Apr 26, 2017 08:24 AM
nlareau
May 26, 2011 08:12 AM
260falcon
Nov 8, 2005 10:01 PM
FERacing66
Dec 15, 2004 12:15 AM
rick
Dec 5, 1999 08:57 AM
