The motor is in.........problem
Old Dec 12, 2004 | 09:54 AM
FERacing66's Avatar
FERacing66
Exclamation The motor is in.........problem
Hey there I just got my motor in last night and I have a problem. The bellhousing bolt on the drivers side is so close to the firewall that I cant get the bolt in. Is there and trick to doing this, or am I gonna have to pull it too put it in? Also, if I cant get it in, would it be safe to run it without that bolt?
Thanks again for all the help
FERacing66
Old Dec 12, 2004 | 10:16 AM
gtex's Avatar
gtex
is this an engine conversion? Did you have to use custom motor mounts or anything different. It's a pain to get to the bolts, just because of where they are located (you have be almost on the engine, very awkward), but it's certainly possible on the 67 and 69 FE powered trucks I have worked on. I use a swivel-head 1/2" ratchet (22" long for some oomph) and socket.
Old Dec 12, 2004 | 01:00 PM
Scouder's Avatar
Scouder
When I first got my 76, somebody had drilled a hole in the firewall to get the bolt in. I don't know of any trick. Good luck.
-Scouder
Old Dec 12, 2004 | 04:00 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I think your best bet, Beside's what Greg has allready told you ...is to get the motor and Trans at a rake... to put the bolt in?? Ya know motor High in the front and tail shaft low ....with the motor pulled as far to the fron as you can to make room for hands and tools?? Just a tought??
I allways install motor and trans toghether? It take's care off alot of BS...
Russ Good Luck!!
Old Dec 12, 2004 | 04:11 PM
Lord Yod's Avatar
Lord Yod
What RapidRuss said, get an engine hoist and let the engine off of its mounts so you can wiggle it around to bolt up the bellhousing. This should get you a couple of inches of wiggle room.
Old Dec 12, 2004 | 06:23 PM
FERacing66's Avatar
FERacing66
No its the same. This is the middle bolt between the upper and lower bellhousing bolts. I ran it today without the bolt with no problems, but Im gonna have to take care of it.........someday.
Old Dec 12, 2004 | 06:49 PM
rusty70f100's Avatar
rusty70f100
Could you do some light firewall modification to make room for it? Just a few minutes with a hammer and you'd probably have it.
Old Dec 12, 2004 | 07:19 PM
baddad457's Avatar
baddad457
As long as all the other bolts are there along with the alignment pins, I don't think you'll have a problem missing just one bolt, especially if the others are tight.
Old Dec 12, 2004 | 07:20 PM
FERacing66's Avatar
FERacing66
Thats what Im thinking as well, I wonder how thick the firewall is? I dont want to break though it.
Old Dec 14, 2004 | 08:39 PM
f-250.4x4.390's Avatar
f-250.4x4.390
if you can get the bolt started see if you can then get a swivel socket, or a socket with a swivel and a looooooong extension, like 2-3 foot and stick it up in there from behind the tranny, onto the socket, might need 2 people to do this, but the guys i know do it all the time at the local mech. shop.
Old Dec 14, 2004 | 09:47 PM
highrider76's Avatar
highrider76
Missing bolt
From my personal experience I would never run and engine with a missing bolt.
I broke a bellhousing with a truck that i choose not to install it. I believe it was the combo of the missing bolt off-roading and lighting up all four on pavement. SO be extra cautious of little things like this if your gonna be beating on this truck.
Old Dec 15, 2004 | 12:15 AM
FERacing66's Avatar
FERacing66
Thanks for the advice highrider, I will defintly get that bellhousing bolt in before I hammer on it. I plan to drive it calmly, but I will have some fun with it as well.
FERacing66
May 29, 2006 07:30 PM
FERacing66
Oct 15, 2004 04:20 PM
FERacing66
37
Jul 11, 2004 01:44 AM
FERacing66
Apr 22, 2004 09:52 AM
FERacing66
Exhaust Systems
Feb 29, 2004 09:41 PM
