6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
HELLPP
Old Sep 28, 2014 | 05:12 PM
paniolo38's Avatar
paniolo38
Angry HELLPP
A major half asleep/blond mistake
I have a F450 2008 and put gas in it last night. I got about 6 gallons in it before I noticed and I never started it, I had it towed home.
How do I fix this?? I have two horse hauling jobs in the next few days and am desperate!!
Old Sep 28, 2014 | 05:20 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Well if you haven't started it or turned the key on you will have to pull the tank, drain it, clean it and re-install it. If you turned the key on well then you have more work to do.
Old Sep 28, 2014 | 05:21 PM
Tim Young's Avatar
Tim Young
Welcome to FTE by the way.
Old Sep 28, 2014 | 07:28 PM
kper05's Avatar
kper05
Did you or the tow truck driver turn the key to on to put the truck in neutral?
If so, there could be gas in the DFCM and fuel lines since the LPFP turns on at key on, or at least it does with the 2011+.
It's a lot of work on the 6.7L. Sounds like you have the 6.4L.
Maybe a moderator can move your thread to that section so those guys can provide better advice for your fuel system.
Here are the basic steps for the 6.7L with contaminated fuel.
Procedure B – Fuel Contaminated, Engine NOT Started
1. Drain fuel tank completely by removing the tank and cleaning to prevent the possibility of reintroducing
contamination. (Dispose of contaminated fuel in accordance with local laws and regulations.)
2. Fill fuel tank with fresh, clean, good quality diesel fuel.
3. Using an appropriate container, drain DFCM of any residual liquids.
NOTE: The DFCM must be inspected during filter replacement to verify no low pressure fuel system damage.
4. Replace both fuel filters (primary and secondary).
5. Perform Fuel System Flush. Refer to Procedure C, below.)
Procedure C – Fuel System Flush
1. Remove the rear Fuel Cooler Line that returns to the fuel tank at the fuel cooler.
2. Install a 3' length of 3/8" rubber hose over the fuel cooler nipple.
3. Place the open end of the hose into a suitable container.
4. Use Scan Tool Active Commands or cycle the key to activate the low pressure fuel pump to flush the lines.
Old Sep 28, 2014 | 07:30 PM
kper05's Avatar
kper05
For some reason editing a post erases all text so I'll post this separately.
Here's a similar situation I found in the 6.4L section from April 2013.
https://www.ford-trucks.com/forums/1...of-diesel.html
BTW, you may be in a hurry but this is worth correcting the proper way or you'll end up with a very expensive fuel system repair later.
Fuel system repairs on the 6.7L can be nearly $10,000.
Old Sep 29, 2014 | 08:15 PM
Maxium4x4's Avatar
Maxium4x4
Got you moved to the 6.4L forum, enjoy your stay and Welcome to FTE.
Old Sep 29, 2014 | 08:59 PM
RM2738's Avatar
RM2738
Drop the tank for sure. If the key was cycled, you'll have to flush the entire system.
f3501999
22
Jul 31, 2010 02:40 PM
Cobratodd
Apr 22, 2010 10:49 PM
team5150
Feb 6, 2010 08:34 PM
swhite832
Jan 17, 2009 02:53 PM
Brownie575
Apr 24, 2007 05:25 PM
