i have a 1999 f350 7.3 with 202000 i was driveing about 35 mph and the truck stared to act like it was running out of fuel and it cut off . i was able to start it up again but it wold only runn at idle speed . iput 10 gallons of fuel in it just to be sure it had enough fuel since it was at an eighth of a tank. then it started and ran for about 3minutes and acted like it was running out og fuel agian.already changedthe fuel filter
Does your glow plug light come on then go off after a couple of seconds when you turn the key to on? Can you hear the fuel pump humming for 20 seconds after the key is turned on as mentioned? How's your engine oil level?
Still got the scanner handy? Watch voltage while cranking. Below 10.5 volts we've seen issues where the IDM would not fire the injectors. Low ICP is still a concern. How full is your engine oil? Any blown fuses?
The truck may have an aftermarket chip installed in 99-00, I have looked everywhere and can not find anything that would resemble such a thing. Where could it be?
