Hot No Start Please Help
Old Sep 21, 2014 | 10:58 PM
cope1972's Avatar
cope1972
ok late 04 I have replaced hpop, ipr, icp, d-plugs, Stand Pipes, j-tube, nipple cup orings and pulled injectors only found one that has a bad inner seal replaced it. truck starts great cold but still have a Hot No Start! My thought is i may still have a bad ipr. When hot at idle i have seen 544 psi from hpop and 70-80% ipr when i was driving it the other day at 3,000 rpms i was in the throttle a little i had 1461 psi from hpop and 83.9% from ipr. once hot shut it off then try to restart i have 479 psi from hpop and 83.9 from ipr. This leads me to feel that my ipr is bad, i'd like to test it but not sure if there is a way to test the ipr sensor? Any help would be greatly appreciated cause i've about lost my patience with this!
Old Sep 22, 2014 | 06:23 AM
mustang_309's Avatar
mustang_309
What are your ICPV's at KOEO? Also if your engine has the wavy oil rails, when you had the oil rails out did you replace the oring on the small plug on the top side of the oil rail? Have you done an air test since the work was done?
Old Sep 22, 2014 | 06:51 AM
cope1972's Avatar
cope1972
I will have to check icp volts. Oil rail is not wavy. And going to do another air test today..
Jack3d_Dually
Oct 27, 2018 09:07 AM
painandgain
May 23, 2018 09:58 AM
waistline00
Aug 26, 2017 06:24 PM
sandflea1
31
Jul 23, 2016 05:00 AM
cope1972
Oct 7, 2014 04:12 PM
