Hot no start
Old May 18, 2014 | 08:09 PM
cope1972's Avatar
cope1972
Hot no start
I've changed hpop, icp, ipr, d - plugs and stand pipes and still have hot no start.... any advice or suggestions?
Old May 18, 2014 | 09:00 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
Have you air tested the system to check for leaks or monitored the icp and ipr during cranking? Could be the orings in the oil rails or upper fuel injector o-rings.
https://www.ford-trucks.com/forums/1...ole-story.html
Old May 19, 2014 | 10:22 AM
cope1972's Avatar
cope1972
i did air test before i replaced pump.. guess i need to do it again..
Old May 19, 2014 | 11:28 AM
Amarillo60's Avatar
Amarillo60
What is your oil PSI while cranking? Ficm voltage?
Old May 19, 2014 | 02:57 PM
cope1972's Avatar
cope1972
I know my ficm is good I've tested it 3 times in last week between changing everything I've done but I'll check it again.. fixing to go drive it to get kids from school and get it hot and test it..
Old Sep 17, 2014 | 08:08 AM
JohnInCanada's Avatar
JohnInCanada
Following. I'm having a similar problem.
Old Sep 17, 2014 | 08:31 AM
cope1972's Avatar
cope1972
John I replaced everything except injector seals before I did an air test. If yr having a hot no start I'd highly suggest doing an air test before throwing parts at it. It will save you time, money and lots of frustration! If I can help let me know..
Old Sep 20, 2014 | 08:42 AM
JohnInCanada
Thanks. I'm taking it in to a diesel shop on Monday to get it up and running. It's waaay beyond my ability to repair.
Reading this thread has helped me to at least understand the issue, so I can fake an educated discussion with the mechanic!
Old Oct 7, 2014 | 08:37 AM
JohnInCanada
Sorry for the late reply. You called it, an injector seal. $10 plus 7 hours of labour.
Old Oct 7, 2014 | 08:41 AM
cope1972's Avatar
cope1972
7 hrs labor lol... I had it apart all 8 seals replaced and back together in 4 hrs...
Old Oct 7, 2014 | 11:11 AM
r2millers's Avatar
r2millers
Have you replaced the MAP vacuum hose running off the passenger side valve cover? (Never mind, thinking of low boost, not a no start condition)
Kinda interested in what you saw with diagnostics to change out all of these other parts first?
Sounds like you work on this guy yourself, especially if you could change out all 8 o-rings on both sides in 4 hrs.
It took me 4-5 hrs to replace a couple of injectors on just the drivers side alone.
Last edited by r2millers; Oct 7, 2014 at 11:36 AM. Reason: Map vacuum hose changes
Old Oct 7, 2014 | 04:12 PM
cope1972's Avatar
cope1972
With the proper tools and working o. These trucks quite often it doesn't take that long to pull 2 valve covers and rail and have injectors loose. I was throwing parts at it instead of properly diagnosing it first. Because of my experience in doing that I always stress to everyone now to diagnose it correctly first that way yr not throwing parts and money at it.. that is just my personal experience.
cope1972
Dec 16, 2014 06:47 AM
cope1972
Sep 22, 2014 06:51 AM
ROBBINthaHOOD
Nov 4, 2013 12:44 PM
Green1995GT
Oct 1, 2013 11:04 AM
dirtleg
Nov 6, 2010 02:05 PM
