Sponsored by: Auxito
Mobile 1 oil filter
Old Sep 20, 2014 | 05:25 AM
jake22si's Avatar
jake22si
Mobile 1 oil filter
I just did my first 5.4 ford triton oil change and used 5w20 mobile 1 and a mobile 1 oil filter because it came with the oil. Is this an acceptable filter or should I switch it out to a motor craft?
Old Sep 20, 2014 | 08:08 AM
Marty N Debbie Sapp's Avatar
Marty N Debbie Sapp
Th mobile1 filter should be fine. Just don't use fram
Old Sep 21, 2014 | 08:34 PM
blupupher's Avatar
blupupher
Mobil 1 filters are good filters, just costly.
Old Sep 21, 2014 | 08:45 PM
jake22si's Avatar
jake22si
Good to know, thanks.
Old Sep 21, 2014 | 10:05 PM
F91's Avatar
F91
I gotta ask, why not Fram? I just put a PH-2 on my 4.6! What's the issue?
Old Sep 21, 2014 | 10:48 PM
fourty03's Avatar
fourty03
Various studies on oil filer design and quality show that the Fram (the orange and some "tough" branded filters) do not have the anti-drainback valve.
The "valve" is basically a stiff rubber diaphragm which sits inside the filter that prevents the oil from draining back into the oil pan when the engine is not running. Especially when the engine has been shut down for the day...
The rubber diaphragm (the Anti- Drain - Back valve) prevents a "dry startup". If the oil has to recirculate and refill the oil filter before full pressure builds up, the engine will run somewhat dry until the filter is filled with oil first.
With the anti-drain back valve, oil is already in the filter ready for the next engine startup.
The oil pressure pushes open the rubber diaphragm when the engine is running.
I found out a while ago that motorcraft oil filters are identical to the Mobile -1 filters which are good quality (only difference is that it's a few dollars cheaper cost wise)
Old Sep 22, 2014 | 06:45 AM
F91's Avatar
F91
This makes sense. Ever since my oil change, my start ups have been quite bit noisier. Suspected that an anti-drain back valve could be the issue. Thanks for the info!!!
Old Sep 22, 2014 | 07:25 AM
2Fords1Jeep's Avatar
2Fords1Jeep
I've used NAPA Gold 1372 on all my 5.4L ford trucks.
Old Sep 22, 2014 | 02:16 PM
blupupher's Avatar
blupupher
NAPA Gold are re-branded Wix, and Wix are also excellent filters.
I have almost always used Wix filters on my other vehicles, but with the Motorcraft filters being only $3.75 or less @ Walmart and having a silicone ADV like the Wix with equivelant filtration, why spend $7 on a Wix when the Motrcraft will work just as well for about 1/2 the price.
One of the few times that the OEM filter is just as good (or better in many cases) than aftermarket, is cheaper (even cheaper than the orange can Fram) and readily available.
Old Sep 23, 2014 | 06:44 AM
F91's Avatar
F91
I took off the Fram filter last night and installed a Purolator Gold with a silicone ADV. When I first installed the Fram, it was a bitch to get the thing spun on. Thought it was just the design. With the Purolator, had a hell of a time lining it up and spinning it on. Seems like it has to be lined up absolutely perfect. Never had an issue like this with any car or truck.
Old Sep 24, 2014 | 05:45 PM
Dr. Dirt's Avatar
Dr. Dirt
I used to have a 2004 Mazda and I never knew what to use as an oil filter. I figured Mobil 1 was the most expensive so it has to be the best. I later found out that the engine in that car was a Ford engine so Motorcraft was my route from then out for around $5.50 less each time.
Iowa F-150
2004 - 2008 F150
16
Feb 13, 2011 05:10 PM
FarmingFord
Sep 22, 2008 06:34 PM
eco
Oil & Lubrication
Mar 22, 2007 04:08 PM
F-250 diesel
2004 - 2008 F150
32
Feb 8, 2007 10:12 PM
LP2
Oil & Lubrication
Oct 22, 2006 07:30 AM
