Any sage advice ?
Old Sep 19, 2014 | 06:54 PM
eminencefront's Avatar
eminencefront
Any sage advice ?
Anyone got any advice in how to remove a stuck outer front wheel bearing race in a rotor ?
I pulled the wheels to check them out and the cages are in pieces, the races are thrashed...
Guessing if they been rubbing a while they heated up and fused to the cast rotor .
I'm guessing heat is the only option ?
They won't drive out from the back. I tried with a 3lb driver and cold chisel.
I'm worried about warping the hub.
Old Sep 19, 2014 | 08:57 PM
tinman52's Avatar
tinman52
Welder User
Cutting torch would be simplest.
Old Sep 19, 2014 | 09:32 PM
TBird Larry's Avatar
TBird Larry
I tried beating it with a 3 pound hammer and it wouldn't budge. I went and grabbed the 8 pound sledge and after the second blow it popped right out!
Just get a bigger hammer. That's what I always say....
Good luck.
Old Sep 19, 2014 | 09:51 PM
skidoorulz's Avatar
skidoorulz
A chisel is the wrong thing to use, as it cuts into the race as you are pounding on it, it is acting as a wedge expanding the race, much like splitting wood. Use a good heavy punch on the race where the notches are in the back of the hub. 2 or 3 good whacks on one side then 2 or 3 good whacks on the opposite side going back and forth. To many hits on one side and it will wedge it in the hub also.
Old Sep 20, 2014 | 12:59 AM
resonateur's Avatar
resonateur
...or take it to a front-end shop and let them press it out for (using a backup support) to you don't ruin the hub....
Old Sep 20, 2014 | 06:17 PM
eminencefront
Thanks y'all
I managed to remove both front and rear with a steel dowel.
Three whacks and they popped right out. Ran them down to the classic parts store (which I discovered is about 2 miles from me) and Mark pressed them in for me for $10 /rotor.
Well worth it and I got to support a local shop, not a chain store.
Very happy now with fresh pads, fresh bearings and grease, and seals.
Old Sep 20, 2014 | 10:14 PM
1972RedNeck's Avatar
1972RedNeck
If you weld a bead all the way around the race and let it coll it will almost fall out.
enduro4231
Jun 15, 2022 08:48 AM
wyckedcombo17
Jun 13, 2011 11:51 PM
Ak68F250
Jul 20, 2009 01:42 PM
jdubbtx
20
Sep 29, 2007 06:04 AM
gpachner
Apr 16, 2002 10:14 AM
