351w question
Old Oct 24, 2014 | 02:55 PM
  #46
Gigemags05's Avatar
Gigemags05
I checked engine compression and all cylinders were within 1-2 psi of each other.
I bought an edelbrock 1406 for it and am searching for an intake.
I am still undecided on camshaft and I am not really sure how to make a choice.
Old Oct 24, 2014 | 04:48 PM
  #47
Gary Lewis's Avatar
Gary Lewis
Pick one by the operating range. A truck needs one that pulls from idle up. Like Comp's 252H.
Old Oct 24, 2014 | 04:51 PM
  #48
FordFETruck's Avatar
FordFETruck
Just a heads up about the 252H. That's what appeared to be in my truck when I bought it. And it was the most torque-less turd of a cam below 1700 RPM. I now have an XE250H and it has much stronger low end torque and the MPG averages .5 MPG better over the 252H.
Old Oct 24, 2014 | 05:00 PM
  #49
Gary Lewis's Avatar
Gary Lewis
Actually, I misspoke. I did mean the XE250H. Like Matthew I had one and it would turn the tires from idle on concrete. Very strong from idle.
Old Oct 25, 2014 | 04:58 PM
  #50
Gigemags05's Avatar
Gigemags05
Dumb question:
I know the cam's from a 302 and a 351w will interchange, but are there performance differences when it's in a 351w with factory heads?
Also, do I need new rocker
Arms? Valve springs? Etc? I was planning on new lifters but keeping the rest.
Would I be better off just
Sucking it up
And buying one of the kits?
Old Oct 25, 2014 | 05:30 PM
  #51
Gary Lewis's Avatar
Gary Lewis
New lifters are absolutely required with a new flat-tappet cam. The old lifters have mated to the old cam and will be destroyed in short order if even moved to a different lobe on the same cam, much less moved to a new cam. And, your timing chain needs to be replaced if it has very many miles on it, so you should buy a kit.
As for comparing a cam for 302 to one for a 351, a mild 302 cam will have less duration and/or lift than one for a 351. If you think about it, most 351W heads have the same runner and valve sizes as 302 heads, but you have to get 16% more air and fuel through them. So you need more lift and/or duration to get the same effect.
Old Oct 25, 2014 | 08:14 PM
  #52
FordFETruck
New valve springs are recommended with the new cam. Rocker arms aren't required. You can use your stock rockers if you like. I run the Comp cams Magnum series roller tip rockers. Very well built for the price. However, they make the engine sound like it has a solid lifter cam in it.
Gibby55
Feb 11, 2011 09:01 PM
tkeduck
27
Jun 5, 2009 07:50 PM
BigDave74
Jun 22, 2007 08:32 AM
gavin
Dec 30, 2003 10:52 PM
hairball12
Dec 21, 2003 11:49 PM
