Link to instructions for bubble test?
Old Sep 18, 2014 | 01:07 PM
IHateCommieCars's Avatar
IHateCommieCars
Also, any recommendations for a good fuel pressure gauge?
Old Sep 18, 2014 | 01:46 PM
Maxium4x4's Avatar
Maxium4x4
https://www.ford-trucks.com/forums/1...l#post11648476
Old Sep 18, 2014 | 03:23 PM
IHateCommieCars
Thanks, no bubbles!
Old Sep 18, 2014 | 05:22 PM
Maxium4x4's Avatar
Maxium4x4
No bubbles eliminates one probable cause, are you having trouble?
Old Sep 18, 2014 | 06:33 PM
IHateCommieCars
Trouble?
For awhile now. https://www.ford-trucks.com/forums/1...elp-again.html
It's running pretty good now, but there's still a little miss when I give it gas at low rpms. The bubble test helped, now I'm pretty sure the injectors are not leaking. Ford mechanic says my FICM voltage is all good, and no codes are being thrown up except one bad glow plug, and it was showing that before any of these problems started.
I think I'm down to the fuel pump or a restriction in the fuel lines somewhere. Just hate to pay $500 for a new one without knowing for sure (mostly because I've already paid out close to $4000 throwing parts at the problem.)
You know of any cheap way to test the fuel pump? When I take the primary filter and cap off and crank, it sure fills up like the fuel pump is working, but maybe it's just not enough pressure. Already did the blue spring upgrade - and it needed it bad, all gunked up.
AlexG21
Mar 2, 2014 07:26 PM
run6.0run
Nov 11, 2012 02:03 PM
kupaa
May 17, 2010 10:02 AM
jwheatley20
Feb 10, 2010 03:10 PM
VQ2Fast4U
Aug 4, 2007 06:31 PM
