VIN decoding for engine?
Old Sep 16, 2014 | 11:24 AM
alchemist1's Avatar
alchemist1
I looked up the typical codes on a truck that a friend has for sale, in the Fordification section and the codes aren't quite right. He has for sale a very nice body F100, 1973 2WD. No rust.
Code is: F0ZER00946
133 HO F101
F4 G17
0450
Since he's close to 70, I kinda thought he misread some numbers, so thinking the F0 should be F10?
On the engine code, I don't see a Z? But could this be the infamous 360 low compression made in Canada? Ugh. E would be the Manwah plant, I think.
133 is long wheelbase. I can't find an HO paint code. F101 is obvious.
G is auto transmission and 17 should be 3.25 ratio.
0450 is the weight
Old Sep 16, 2014 | 01:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Code is: F10ER00946 / W.B. 133 / COLOR: HO / MODEL: F101 / BODY: F4 / TRANS: G / AXLE: 17 / MAX GVW LBS: 04550 / DSO: Omitted.
The VIN contains 11 digits, there's only 10. It appears that the engine code (4th digit) is missing, because there's no E, R or Z VIN engine codes listed for F100/350's.
F10 = F100 2WD Pickup.
Possible engine codes: A = 240 I-6 / B = 300 I-6 / G = 302 2V / H = 390 2V / Y = 360 2V
E = Mahwah NJ Assembly Plant.
R00946 = 1973.
133" Wheelbase.
F101 = F100 2WD Pickup, 4550 lbs. GVWR
HO: H = Medium Green Metallic / O is incorrect, it's probably Q = Light Yellow Green.
F4: F = Medium Green Vinyl & Medium Green Cloth / 4 = Ranger Cab with Styleside Pickup Box.
G = Automatic Transmission: 240/300/302 = C4; 360/390 = C6.
17 = Ford 9" Rear Axle / 3.25-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
4,550 lbs. Gross Vehicle Weight Rating.
btw: Low Compression 360 2V was only available in 1974, its VIN engine code is 5.
Old Sep 16, 2014 | 01:36 PM
alchemist1's Avatar
alchemist1
R00946 = 1973.
133" Wheelbase.
Yes, you're correct - I mentioned that above about a missing digit (thinking he meant 'F10' instead of 'F0'. So if that's the case, you have 'Z' as the engine code. I read a thread somewhere that Z was the designator in Canada for a 360 engine, low compression, D.S.O.???
In other words, pretend the VIN is F10ZER00946...
Old Sep 16, 2014 | 01:41 PM
NumberDummy
Whoever typed that nonsense didn't know what they were talking about!
Z is not the code for the Low Compression 360 engine...which was only available in 1974. It's 5 and was a Domestic Special Order (parts catalog makes no mention of Canada).
When a vehicle is a Domestic Special Order, the DSO code stamped on the 3rd line...far right of the Warranty Plate...contains 6 numbers, instead of the usual 2.
Where is the Z VIN engine code? No see um.
Old Sep 16, 2014 | 01:44 PM
alchemist1's Avatar
alchemist1
OK, so only available in 1974. that's good - he must have not had his thick reading glasses on when he copied down the VIN. If it's a 390, I might go for it. How would a 74 truck 390 compare to a non-HO 390 in an earlier model automobile (like a Galaxie, Fairlane, Mustang)?
Old Sep 16, 2014 | 02:02 PM
NumberDummy
First, you have to measure the stroke to verify it is a 390. Then you have to take into consideration if it has an EGR valve and/or smog pump.
IMO, the 390 used 1961/65 in cars is more powerful than the truck 390.
Old Sep 16, 2014 | 02:08 PM
alchemist1's Avatar
alchemist1
Bill,
Actually I do see Z in the engine code column. It shows as D.S.O. (not low compression DSO). Here's the link where you posted that Z is referring to DSO:
https://www.ford-trucks.com/forums/6...a-360-a-2.html
Old Sep 16, 2014 | 03:00 PM
NumberDummy
I should have said, where is the Z engine code for the 360 Low Compression engine? No see um.
Old Sep 16, 2014 | 03:06 PM
alchemist1's Avatar
alchemist1
Do what does the Z engine code stand for? there's no definition in the Ford table.
Old Sep 16, 2014 | 03:14 PM
NumberDummy
Dunno, parts catalog doesn't say. All it says is D.S.O.
Old Sep 16, 2014 | 03:54 PM
alchemist1's Avatar
alchemist1
sorry for the multiple posts Bill.
Here's what the VIN reads (corrected by the old man who just now called):
F10GER00946
So the engine is a 302, correct?
Old Sep 16, 2014 | 04:25 PM
dlburch's Avatar
dlburch
at least the truck with that VIN left the factory with a 302...the only way to say for sure is to see pics...
Old Sep 16, 2014 | 04:32 PM
alchemist1's Avatar
alchemist1
Wouldn't it be a big deal to go to a big block from a 302?
Old Sep 16, 2014 | 04:50 PM
jim collins's Avatar
jim collins
I did it on a 79 F-100 i sold later, but i had all of the parts from another truck i pieced out . Big radiator that came with the 460 ,fan shroud correct factory 460 motor mounts, 79 engine , C/6 transmission . The drive shaft i can't remember if the F-100 one worked or if i just had one in my parts pile.That's the major parts , most of the time you have to reroute some wiring and a few other misl. things.
I did my 73 just the opposite , removed FE-360 , standard transmission and went with a 302 with AOD transmission . About the same amount of work, it's all about what you like and can live with.
ThinkItBuildIt
33
Jun 13, 2019 08:57 PM
Stang65fst
Oct 1, 2010 09:19 AM
Angry Slide
30
May 31, 2005 04:18 PM
harrisongd
Mar 15, 2004 09:19 AM
SFC DAVIS
Dec 31, 2003 07:41 PM
