How to Decode
Old Sep 29, 2010 | 10:40 AM
Stang65fst's Avatar
Stang65fst
How to Decode
I bought a 1968 F100 Ranger with F10YNC which I have got to F100, Y- 390, N= Norfolk, VA but the door tag I cannot find any info on. Where is a good place to find a door decoder? I know for my Mustang I had no issues finding one. Anyone help?
Thank You
WB = 115, Color =A, Model = F100, Body = N, Axle = 81, Trans = C, Axle = 17, 05000 GVW, 172hp, 3800rpm, 25 DSO
Old Sep 29, 2010 | 11:45 AM
BobbyFord's Avatar
BobbyFord
Try this:
Decoding Your 1968 Ford Truck VIN - FORDification.com
Old Sep 29, 2010 | 05:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Stang65fst
I bought a 1968 F100 Ranger with F10YNC which I have got to F100, Y - 390 Y = 360 2V N = Norfolk, VA
WB = 115, Color = A, Model = F100, Body = N, Axle = 81 BODY: N81 Trans = C, Axle = 17, 05000 GVW, 172hp, 3800rpm, 25 DSO
Welcome to FTE
As you can see, I made a few corrections.
F10 = F100 2WD
Y = 360 2V / H is the VIN engine code for a 390 2V (see below).
N = Norfolk VA Assembly Plant.
C = 1968 / 1968 serial number range: C00,001 thru D82,000.
115" Wheelbase.
A = Raven Black.
F100 2WD, 5,000 lbs. GVWR
N81: N = Dark Red Crinkle Vinyl & Red Granada Pattern Vinyl // 81 = 81B Custom Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
17 = Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 3800 RPM
25 = Richmond VA Ford District Sales Office, where the original selling dealer ordered the truck from.
inre to VIN engine codes H & Y: H = 1968/76 F100/350 390 2V / Y = 1966/67 F100/350 352 2V / Y = 1968/76 F100/350 360 2V
If you got this Y-390 jazz off the FTE VIN decoder, be aware that the FTE VIN decoders aren't worth two cents, have all sorts of errors and omissions.
Since 11/2006, I've decoded over 700 VIN's and Rating/Warranty Plate & Certification Label codes for FTE members using the apropos Ford parts catalogs.
Old Oct 1, 2010 | 09:19 AM
Stang65fst's Avatar
Stang65fst
Thanks Bill. It is greatly appreciated. Thanks for being so kind.
Vegasw0lf
Aug 1, 2013 06:17 AM
Ford52F2
Virginia Chapter
43
Apr 8, 2010 08:50 PM
Shane in WI
31
Jan 7, 2010 09:34 PM
77f100rcsb2wd
Dec 15, 2009 05:34 PM
B. Abel
Feb 12, 2005 12:34 PM
