I just bought a 2001 ranger xlt 4x4 3.0.. it already had a cold air intake just noticed thst the iat is missing and the wireing is gone.. how do I rewire the iat?? just wondering if you can run it off the maf or do I need to go to the ecm?
I just checked, and the 2001 Ford Manual Wiring Diagrams (Section 303-14B-00-001 Electronic Engine Controls) shows the IAT as part of the MAF assembly (gray wire, pin #6 at the harness connector). So, either the wiring diagrams are wrong, or the parts store that sold you the "replacement" IAT is wrong.
This is why it is important to know exactly which IAT code(s) you are dealing with.
Also, there are times when people prefer to have an IAT sensor mounted separate from the MAF. In such cases, the IAT wires are cut at the MAF harness, and an IAT harness connector is spliced in, allowing for a stand-alone IAT sensor to be plugged in and relocated to another part of the air intake tube.
