IAT Sensor
Old Nov 25, 2009 | 02:06 PM
Bovaloe's Avatar
Bovaloe
IAT Sensor
So just did a MAF conversion. Took a wiring harness from a 95 and put it in my 91. Everything worked out but the one question I have left is about the IAT sensor( located in the air box before the MAF stock).
I cant find where to put the wire that goes into the ECM. The pinouts and wiring diagrams I have either say ACT( located on lower intake) or just dont have the sensor on them.
I dont remember if the donor truck had both or not but all the info I can find uses the 2 sensor names interchangeably, so do I need both or is one or the other good enough?
Which one should I use if it is?
I used the pinouts on here:
Ford Fuel Injection
I used my Haynes manual and any wiring diagrams i could find on the internet and cant figure it out.
Old Nov 25, 2009 | 03:11 PM
Conanski's Avatar
Conanski
ACT stands for Air Charge Temperature and IAT is Intake Air Temperature which is the same thing and you only need 1 of them.
Old Nov 26, 2009 | 09:31 PM
Bovaloe's Avatar
Bovaloe
Ok got that. is one better than the other or whats the deal?
I have the ACT hooked up now but the IAT sensor and wire is just hanging out in there and could be plugged in no prob.
So which one should I use?
Old Nov 26, 2009 | 10:33 PM
Conanski's Avatar
Conanski
It's just a different name for the same thing so get a sensor and plug it in. On earlier motors the air temp sensor was located on the lower intake but it was moved out to the airbox later on.
boston1918
May 17, 2017 01:27 AM
Kevint343
2004 - 2008 F150
Sep 12, 2015 11:50 PM
MFogarty1996
Apr 20, 2013 07:10 PM
itsaford
May 20, 2010 12:58 AM
Peter94
1983 - 2012 Ranger & B-Series
Aug 29, 2003 10:35 AM
