Egr cleaning
Old Sep 15, 2014 | 08:15 AM
Iaff113's Avatar
Iaff113
Egr cleaning
Can I use carb cleaner?
Old Sep 15, 2014 | 08:52 AM
ves83's Avatar
ves83
That's what I used(doesn't make it right though). Theres a thread in the tech folder on it. They said not to use brake cleaner use carb cleaner instead. I had to use a crows foot to get my EGR out as well.
Old Sep 15, 2014 | 08:56 AM
Iaff113's Avatar
Iaff113
Yeah I was reading the tech folder and I think the first post said brake clean but I thought i saw somewhere to use carb clean
Old Sep 15, 2014 | 09:21 AM
ves83's Avatar
ves83
It does some use brake cleaner and some use carb cleaner. I went with the carb. I think as long as you don't get all ***** nilly with it you will be ok. Just don't get any in the two holes on the bottom of the EGR.
Old Sep 15, 2014 | 09:25 AM
bismic's Avatar
bismic
Ford says specifically not to use brake cleaner, but to use carb cleaner instead. Some folks have had a bad enough mess that they felt that they had to use brake cleaner. I can't comment on that, except keep the fluid out of the electronics and don't leave it exposed to the shaft seal too long. I have always been able to get Carb Cleaner to work.
Old Sep 15, 2014 | 10:05 AM
Iaff113's Avatar
Iaff113
Yeah just pulled mine only had a light dust of carbon so just sprayed it real good and wiped it. Also when putting the egr back I'm seeing it doesn't seat all the way down. Is this ok and just put the screws back in to seat it?
craypc
May 13, 2013 07:32 PM
VQT
Mar 19, 2012 10:21 PM
Erik727
Mar 6, 2011 05:29 PM
npccpartsman
May 11, 2010 07:16 AM
slowmans
Apr 11, 2007 08:25 PM
