egr cleaning... tech's
Old Apr 11, 2007 | 06:59 AM
slowmans's Avatar
slowmans
what is the best solvent to clean the egr with some say carb cleaner some say brake cleaner? and will i need new o-rings or can i reuse the old ones? thanxs guys oh ya ill post pics later---22k on the clock
Old Apr 11, 2007 | 07:03 AM
BowTieHatr's Avatar
BowTieHatr
carb cleaner only. you will need to replace the orings as carb cleaner will eat them up.
Old Apr 11, 2007 | 07:09 AM
slowmans's Avatar
slowmans
thanx bowtie, i was hoping you were lurking around.....
Old Apr 11, 2007 | 11:11 AM
BowTieHatr's Avatar
BowTieHatr
youre welcome. if its not bad i wouldnt clean it at all. some soot is normal, but if it makes you go wow clean it.
Old Apr 11, 2007 | 08:15 PM
slowmans's Avatar
slowmans
sorry guys no pics? it really wasnt that dirty, but i cleaned anwyas, i used the carb/fuel injector cleaner you add to your gas in a gas vehicle. i think it worked great... took me verry little time with a toothbrush to get it down to metal? maybe the ulsd has something to do with it, like i said i have 23k now, ive never towed, 80% highway miles always use dk- whit/grey, and very rarely idle the truck for more than 3 minutes only when its cold out?
Old Apr 11, 2007 | 08:25 PM
a-rod's Avatar
a-rod
I just cleaned mine, it was pretty gunked up, I actually cleaned it with electric motor cleaner, gasket and o-rings looked ok. trucks been blowing a little white smoke in the mornings so we will see if this helps.
Iaff113
Sep 15, 2014 10:05 AM
pmoney1983
Aug 20, 2012 07:03 AM
VQT
Mar 19, 2012 10:21 PM
npccpartsman
May 11, 2010 07:16 AM
roperjoe
1997 - 2003 F150
Apr 10, 2008 07:42 PM
