6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
No high beams
Old Sep 13, 2014 | 07:39 PM
Washbish8762's Avatar
Washbish8762
No high beams
I have no hight beams in my 2008 6.4. Not even in the flash to pass position. I put new headlights on it so it's not the bulbs. I'm not sure where both fuse panels are. I checked the one under the hood and found no bad fuses. I'm not sure if there is one inside the cab, if so I don't know where it is... Any suggestions?
Old Sep 13, 2014 | 10:22 PM
wp6529's Avatar
wp6529
The headlights (and other lighting) is controlled by and the fuse for them are in the SJB (Smart Junction Box) located in the passenger footwell on the right side. There is an access panel you remove to access the SJB. It should be fuse F23 15A.
Old Sep 14, 2014 | 09:02 PM
Washbish8762
Ok so I checked that fuse and it is good. What should I do next? Could it be in my switch?
Old Sep 14, 2014 | 10:30 PM
73fan's Avatar
73fan
I know that you stated you had changed headlights, but sometimes it is worth double checking. Also, is there power to the fuse? A digital volt meter or even a simple test light would work. Find a good ground, and with high beams on, test the little metal on back of fuse. If there's good power there, remove a headlight and check voltage at the headlamp plug.
Sent from Nexus 4. IB AutoGroup
Screwed 05
2004 - 2008 F150
Aug 31, 2017 03:03 PM
Shane Forbes
Oct 23, 2016 07:14 AM
roree
Jul 10, 2008 02:51 PM
76 F-150 390FE
Electrical Systems/Wiring
Mar 20, 2006 07:21 AM
rebel_gtc
Aug 4, 2004 02:59 AM
