high beam fuse
Old Mar 16, 2006 | 09:08 PM
76 F-150 390FE's Avatar
76 F-150 390FE
high beam fuse
my high beam fuse took a crap on me and im wondering where i could find another one. i went to radio shack, nothin, advanced nothin, all other auto parts places, nothin. i dont want to get it though ford and get screwd for $15 (not sure if that is the price but probably close) for a 35 cent part. also it is 3 amps right?
Old Mar 16, 2006 | 09:10 PM
Mil1ion's Avatar
Mil1ion
HI beam fuse ?
Headlights don't have fuses.
There is a circuit breaker in the switch.
Is this a trick question ?
Old Mar 16, 2006 | 09:17 PM
76 F-150 390FE
not at all, my fuze block looks fairly new so it might be aftermarket but i have no high beams and on the fuse block there is a place marked hi beams and the fuse is clearly blown. my regular lights work, but the high beams dont. its a really small fuse. i havent been able to get it out yet, i stopped tryin after the piece of metal i was useing sent sparks flyin but some how i didnt get shocked. from what i can read on it it says 3A, ill go take a look at it and update when i get back in.
update: after another shower of sparks i decided to give up again, it was hard to get around under there and hold the lighter on at the same time. so i decided to draw out a picture of the fuse block. about it saying hi beams, it doesnt but i have tested and when i turn the lights on both sides of the fuse under the blown one become hot and it makes sence to me that the one above it would be the high beam fuse because it is blown and i have no high beams. on the picture red is the blown fuse and gray are the 2 open spots on the block. https://www.ford-trucks.com/user_gal...110027&width=0
Old Mar 16, 2006 | 09:46 PM
Phinxter's Avatar
Phinxter
Heres a crazy idea, before you start doing anything disconnect the battery, and get a flashlight. The fuse might be the control circuit for a relay for the high beams. Not sure why it would be wired this way if it is aftermarket.
Old Mar 16, 2006 | 09:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Since this is not OEM wiring we will send you to the experts down in the Electrical forum.
Old Mar 16, 2006 | 09:53 PM
76 F-150 390FE
well, im tired of disconnecting the battery on this thing and i aint gonna do it right now i was just making an attempt for the heck of it i didnt plan on trying to take the fuse out and i have a sprained ankle and wasnt walking the 100yrds to the garage to get the wrench, if anything i will do it tomorrow and if you could point me in the direction of a flash light that my dad does not take with him i would be very grateful becuase i looked for a good bit and couldent find one.
Old Mar 16, 2006 | 10:16 PM
Dealford's Avatar
Dealford
Both good points. Tomorrow in the daylight, you can continue getting the fuse out.
A 3 amp fuse? OK. That figures in to a relay system like in this article.... https://www.ford-trucks.com/article/...r_Brights.html .
Try tracing the headlight wiring back from the bulbs & maybe you'll locate relays.
AL.
Old Mar 17, 2006 | 04:10 PM
rebocardo's Avatar
rebocardo
You know, if anything, if it was marked 3A on the fuse panel itself, I would say that it was meant for the indicator lights on a replacement dash and aftermarket turn signal switch. The 3A is also suppose to feed the turn signal indictors on the dash and aftermarket turn signal switch (they have little arrows that light up).
If you still have a stock head lamp switch in a 1976 F-150, as Mil1ion has already pointed out, the circuit breaker is in the headlamp switch. If it is bad, it will cause problems. Good news, it is only about $10.
If your high beam switch is on the floor, make sure the switch is not bad, if it is not bad then make sure it is not wired to that 3A fuse
Old Mar 17, 2006 | 05:01 PM
76 F-150 390FE
ok i pulled the fuse and it is 9A and 32V. i guess i saw the 3 of 32 and thought it was a 3A fuse.
Old Mar 18, 2006 | 07:10 AM
Franklin2's Avatar
Franklin2
I hope you get it fixed. I guess this is one problem associated with non-stock or aftermarket components. I would try to figure out what you have so you can get a better handle on getting parts for it. Do you think it's aftermarket or a fuse box from some other type of factory vehicle?
Old Mar 19, 2006 | 09:47 PM
76 F-150 390FE
i really dont know what it is, i would have to see another truck to tell if it is after market or original. it looks too new to be the original that came with the truck but someone could have replaced it with an oem part.
Old Mar 20, 2006 | 07:21 AM
Franklin2's Avatar
Franklin2
I have to agree with Dennis in a previous post higher up on the page. The original factory set-up did not have fuses for the headlights. They were hot wired directly to the switch, and then to the battery. The only protection was a circuit breaker inside the headlight switch. So you definitely have something different there.
Nothins Easy
2015 + Expedition & Navigator
Oct 28, 2014 04:44 PM
livinjeep
22
Mar 18, 2012 03:50 PM
BRay09
Jan 19, 2012 09:29 PM
79outlawf150
Jun 7, 2010 02:41 PM
jerseyjew
1983 - 2012 Ranger & B-Series
Feb 28, 2007 07:21 AM
