01 expedition passenger side headlight
Old Jul 9, 2008 | 08:45 PM
roree's Avatar
roree
Hi all, I need help with this one. I found the headlight out so I replaced the bulb. Hi beam is OK but lo beam is not working. Checked with another bulb, same thing. Checked the socket and wiring all seems OK. The driver side light is fine. Any one had a problem like this before? Thanks.
Old Jul 10, 2008 | 07:49 AM
c_hohensee's Avatar
c_hohensee
I would suspect the multifunction switch at a guess. They can cause some unusual things and since this is where your dimmer switch is....
Old Jul 10, 2008 | 02:51 PM
SPreston2001's Avatar
SPreston2001
Yeah its probably a blown fuse. I had the same problem when I installed my Halo Projector Headlights. I somehow blew a fuse and my drivers side low beam went out. Each of your headlights have a low beam fuse and a high beam fuse. Check your owners manual for the exact fuse slot location in your fuse box. On my Expy slot 16 has a 20 amp fuse that controls the high beams, and slots 26 and 28 take a 10 amp fuse and control the low beams.
gfmk
Aug 28, 2014 09:36 AM
jamesbfishin
Oct 25, 2013 01:45 AM
merlynr
Electrical Systems/Wiring
May 31, 2012 01:46 PM
exlmtd
18
Nov 21, 2003 04:57 PM
opjgeorge
Oct 29, 2002 01:48 AM
