Sponsored by: Auxito
Noisy power windows
Old Sep 11, 2014 | 10:53 PM
jmcder53's Avatar
jmcder53
Noisy power windows
The passenger side power window sounds a little rough, almost like a slight grinding and it raises and lowers slower than the driver side.
This is kind of what happened when the plastic gears crumbled on the passenger side of my ranger. Does this sound like bad gears or could it be something that needs grease?
Old Sep 15, 2014 | 07:01 PM
Dr. Dirt's Avatar
Dr. Dirt
try taking off the door panel and look for the noise while the window moves
Old Sep 15, 2014 | 09:17 PM
steve(ill)'s Avatar
steve(ill)
spray some silicon inside the window track on the top half of the door. spray it down a few inches into the track inside the door. That will help some. Removing the door panel and spraying the linkage with lithium grease and doing the silicon on the bottom half of the tracks will help. If its not too late, that will fix it. If you still have grinding, then it has gone too long and getting wear in the motor / drive unit.
hdman6
Aug 17, 2016 02:11 PM
wlittle
1997 - 2003 F150
Oct 17, 2009 12:50 PM
RobbyMartin
1997 - 2003 F150
Mar 29, 2009 08:58 PM
wiskyseria
Nov 8, 2004 11:01 AM
WXboy
1983 - 2012 Ranger & B-Series
May 1, 2003 08:23 PM
