Sponsored by: Auxito
4.2 starting issue
Old Sep 15, 2014 | 06:57 PM
jbg machine's Avatar
jbg machine
4.2 starting issue
It driving me crazy. Every 10th start of engine it cranks over and over before it fires up, no codes, changed plugs, wires, crank trigger, fuel filter, upper and lower intake gaskets, injectors, iacv. I have no clue. Runs great all time just starting issue every 10th or so start takes 10- 15 seconds to start
Old Sep 15, 2014 | 10:17 PM
Bluegrass 7's Avatar
Bluegrass 7
Respectfully, you spent time and money on everything that would not cause an intermittent no start especially if the motor runs good otherwise.
Have you thought about checking fuel pressure? with a gauge.
The motor needs fuel or it will not start.
What is the fuel pressure with several key on cycles before cranking when the trouble is present?
Good luck.
Old Sep 15, 2014 | 10:55 PM
jbg machine
I checked that 35 psi all time, I'm lost
416bigbore
Aug 14, 2019 05:51 PM
Race4Fun
25
Sep 29, 2009 05:57 AM
Dutch123
1978 - 1996 Big Bronco
Oct 3, 2005 07:27 AM
BRONCO93EB
Apr 8, 2004 08:30 AM
bdonalds
Apr 4, 2001 02:16 PM
