Up pipe blues
Old Sep 9, 2014 | 10:12 PM
bigfordandjeep's Avatar
bigfordandjeep
Up pipe blues
Buddy wanted me to replace his turbo orings over the weekend. I already had orings and donuts for my excursion and he said he would buy a bd wheel for me and one for his. I thought great, changed the orings lots of times at work. Up pipe donuts not so much. Soon as I took it apart I saw alinement problems in my future. Searched a bunch but all I have leared from that is to get the bellowed pipes which will arive for mine tomorrow. Buddy on the other hand says he doesent want to buy them so he has my other truck and his is tore apart in my driveway. Question is how to I get that collector to match up to the turbo! I managed to get the bolts loose at collectors but I've been fighting it for hours! If I pull turbo back off and clamp collector to it will it go back on the pipes while juggling and turbo attached to it? Thanks for any help!
Old Sep 10, 2014 | 06:43 AM
Tugly's Avatar
Tugly
I've heard of people loosening the ups to get the turbo on, but all my work has been with bellowed ups in place - so I have no direct experience with this.
Old Sep 10, 2014 | 11:39 AM
timmyboy76's Avatar
timmyboy76
collector loose, install turbo, attach band clamp, then tighten up bolts with new doughnuts installed...its how i did my friends' ride
Old Sep 10, 2014 | 12:03 PM
Slyhuntr's Avatar
Slyhuntr
I loosely connected the up pipes to the collector and propped them up on the manifolds. Installed turbo than from below tightened up the clamps. Was pretty tough.
Old Sep 10, 2014 | 08:13 PM
bigb56's Avatar
bigb56
From your post it is not clear if you loosened up the up pipes at the manifolds. That is the only way I could get my turbo lined up properly with the collector, both times!
Old Sep 10, 2014 | 08:26 PM
bigfordandjeep
There loose as ever. The collector won't slide up the pipes enough to line up to turbo.
Old Sep 10, 2014 | 09:52 PM
bigfordandjeep
I didn't read that well enough. No I didn't loosen them at the manifolds. I thought of it but changed my mind when I saw the bolts. However that looks like what I'm in for tomorrow night. Took tonight off after two nights in a row of zero progress.
Good news my bellowed pipes for my rig showed up! Imagine they will go smoother.
Old Sep 13, 2014 | 06:31 PM
bigfordandjeep
Loosened them at manifolds and it went right together. Thanks for the help. What a fun job!!!!
PEI
Dec 30, 2011 05:10 PM
dieselboy3278
Apr 30, 2008 09:26 PM
schmuly
Mar 8, 2008 08:39 PM
redneckboy
Mar 30, 2007 11:32 AM
bloomy63
Sep 3, 2006 02:45 PM
