they are leaking i will be ordering some of the international up pipes to elemanate the donuts
my ? is what other parts do you guys think i will need some o-rings for the turbo and do i need ant thing for the pedestal or any other thing you can think of
thanks
darin
Cant think of anything else you might need but i would go ahead and spray all the bolts that will be removed with some PB blaster before you get started maybe even a day in advance. Good luck !
two setsofo-rings,one set pedestal ad one for turbo
hay ray where do you get those orings from i think i will get the pipes from
defuser or does any one of a differnt place to get the pips and o-rings from
you can order them from McMaster Carr online think they come 25 to a pack total about $14 for both
defused may have them but not sure how much $$=edit $30
