New HPOP in, but...
Old 09-09-2014, 08:32 PM
dmueller71's Avatar
dmueller71
dmueller71 is offline
Thumbs down New HPOP in, but...
Got a new problem. New HPOP installed, and it fired right up, but then I see a mist. on the side of the fuel bowl closest to the GPR, the front line has a pin hole about a half inch from the fitting, and its pissing fuel. First, without pulling the spider back off, I cant even see where the other end of this line goes. So how much of a PITA is it going to be to change the whole thing? How much pressure is in this line?, can I cut it and put a compression coupler on the straight section so I don't have to tear the whole damn thing apart again? can I wrap a piece of hose around it and hose clamp it? I really need to have it on the road tomorrow night. Thanks for any help!!!
Old 09-09-2014, 08:49 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
This video is a great explanation of how to change the line the easiest, quickest way.
That line carries about 60 psi fuel pressure.
Old 09-10-2014, 12:15 AM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
So what did you do? I hope you replaced it.
Old 09-10-2014, 04:53 AM
Tugly's Avatar
Tugly
Tugly is offline
If you do, this is also the time to visit your fuel check valves.
Old 09-10-2014, 06:44 AM
dmueller71's Avatar
dmueller71
The video is great. I got everything pulled apart last night? So hopefully the dealership can get me the line today. Thanks for the hook up.
Check valves?? This is the first time I've heard of such a thing
Old 09-10-2014, 07:53 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Crafty Clay of Riffraff Diesel has found another way to make me and now you spend money on your 7.3.
High Flow Fuel CVD Fitting Set - Riffraff Diesel Performance
I plan on getting these as I'm a Riffraff Junkie and it will benefit my already Monstrously Powerful 7.3.
Old 09-10-2014, 08:14 AM
dmueller71's Avatar
dmueller71
LOL. I guess the good thing for me (and my budget) is that the only time that I've been able to find to work on my truck lately is when I NEED to, and time is usually of the essence. Otherwise, I'd also be adding to the pile of money that they make over at Riffraff!!!
Old 09-10-2014, 08:16 AM
Tugly's Avatar
Tugly
Tugly is offline
I still have mine in the box with yellow tape (albeit opened). I took one look at this task and said "I'm gunna need a bigger tool box". I need to get some claw-foot wrenches, an overhead creeper, and mail gloves.
Old 09-10-2014, 08:33 AM
dmueller71's Avatar
dmueller71
It actually wasn't bad to pull off the line. The fitting??? That's another story. I'd probably be pulling the downpipe to get access
Old 09-10-2014, 08:37 AM
Toreador_Diesel
Retired Mod
You won't need the crow foot wrenches, but you will need the topside creeper and gloves. I helped Travis aka Strokin'_Tatsch install his regulated return, part of which was installing new check valves. It's also a very good excuse to get a new tool box and tools.
Sears always has a good "Days after Black Friday" sale. I got a nice set of tools to carry in my Roadside Emergency kit, but this year, I will back my Turbo Diesel up to Sears and buy some tools!
Old 09-10-2014, 06:00 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
I used a socket to get mine off IIRC, make sure you spray the valves with some WD-40 or Break Free the night before.
IBleedOvalBlue
02-13-2012 02:36 PM
jh225
05-11-2010 02:53 PM
SS66
General Automotive Discussion
04-08-2007 06:42 PM
drod
07-25-2004 06:26 PM
JL_Aero
Aerostar
04-08-2004 02:28 PM
Quick Reply: New HPOP in, but...
