Question about steering knuckle.
Old Oct 14, 2014 | 06:44 PM
CharlaineC's Avatar
CharlaineC
ok the part i'm talking about is the rag joint base (not sure of name) that you remove to grind off the two nubs in order to install the new rubber rag. if you look in the photo I posted you can see the hex-socket bolt that was used to secure it. I found out taking it out that it was striped and needs to be either tapped and a helacoil put in or replaced. ( Oldfordjunkie did find me a replacement) i'm not adapting anything, Just trying to fix it properly.
Old Oct 14, 2014 | 07:02 PM
orich's Avatar
orich
Aw you must have move the pix as it won't open now.
It sounds like the flange lock bolts your referring to.
Try reposting the link to the pix
orich
Old Oct 14, 2014 | 07:20 PM
CharlaineC's Avatar
CharlaineC
I dont knw what happened
Old Oct 22, 2014 | 05:27 PM
CharlaineC's Avatar
CharlaineC
Thanks to OLDFORDJUNKY i have a replacement on the way which is great because the truck will be on the road in a week or so
0351mike
1978 - 1996 Big Bronco
Dec 3, 2017 04:47 PM
usuallybowtie
Nov 11, 2014 08:15 PM
Cylina85
Jun 14, 2009 07:04 AM
raydioed
Mar 20, 2004 07:13 PM
porkay
May 21, 2001 03:49 PM
