Truck died
Old Sep 6, 2014 | 11:58 AM
dmueller71's Avatar
dmueller71
Truck died
Ok. Had a pretty major loss of power while on the highway. Stopped on the exit ramp and truck dead. Turns over, but oil pressure guage doesn't move.
I'm thinking LPOP versus HPOP.
OPINIONS???
Old Sep 6, 2014 | 02:29 PM
Tugly's Avatar
Tugly
Pull the ICP sensor connector off and try again.
Old Sep 6, 2014 | 02:56 PM
Pikachu's Avatar
Pikachu
You did pull the dipstick, right? If you have an Allen wrench or an adjustable wrench with you, pop the plug or oil pressure switch out of the HPO reservoir and see how low it is.
dmueller71's Avatar
dmueller71
Well, I actually just went ahead and changed the LPOP as a starting point. It started up and had pressure. I revved it a couple of times to work out any air in the system then it died and wouldn't start again. I got out and heard oil running all over the place. Now there is a handful of parts that I pulled out of the valley. Looks like a small pump and a bunch of spring loaded valves. There is now a vacant hole under the fuel bowl about an inch and a half across. I'm guessing that these are HPOP parts
Old Sep 6, 2014 | 03:35 PM
carltonwebb's Avatar
carltonwebb
That would be the hpop parts. Time for a t500
Old Sep 6, 2014 | 04:20 PM
dmueller71's Avatar
dmueller71
Well, being on a tight budget, I didn't go hog wild on the new pump. I'll have it Tuesday. My concern is, why did it not blow apart while I was driving at highway speeds? Why only after I put in a new LPOP. And rev it up? I did also order the new IPR to go with the new pump, but what would cause such a thing?
Old Sep 6, 2014 | 04:50 PM
carltonwebb
Maybe the air in the system caused a psi spike? No clue. The snapring on mine is leaking and I have been nervous about the same thing happening to me. Hoping it will make it till it cools off a little.
My question was is low on oil before you changed lpop?
Will they accept that as a core with some of the pieces missing?
Old Sep 6, 2014 | 05:01 PM
dmueller71's Avatar
dmueller71
Wasn't low on oil. But also have had a slow leak. Perhaps the snap ring was where I've been getting the leak. I hope they'll take the core. I have all of the parts, they just happen to be in a jar. Lol
Old Sep 6, 2014 | 11:04 PM
Bonanza35's Avatar
Bonanza35
Did you just buy a rebuilt? If so you could of got the T500.
Old Sep 7, 2014 | 03:17 AM
dmueller71's Avatar
dmueller71
I did get a rebuilt for $379. The T500s were too long of a lead time. I'll have it and a new IPR on Tuesday.
Old Sep 7, 2014 | 06:03 AM
Tugly's Avatar
Tugly
Stock LPOP or something else? I'm at a loss as to why the HPOP would vomit valves in the valley.
Old Sep 7, 2014 | 08:51 AM
dmueller71's Avatar
dmueller71
Yep. Stock LPOP. Melling from AZ. Yeah the more I think about it, the more nervous I get about installing the new one. Just some catastrophic failure on the old one? I'd guess that one has been on for 200k. I'd hate to install a new one and have it explode.
greasolution
18
Feb 29, 2016 08:53 PM
Revolv
Dec 13, 2015 11:52 AM
caveman44
Apr 3, 2012 09:08 PM
alanc77
Sep 8, 2007 10:31 AM
Bill_W
Nov 16, 2004 08:32 PM
