Fuel tank question
Old Sep 6, 2014 | 01:35 PM
bielaf's Avatar
bielaf
Fuel tank question
I have searched online haven't really found anything that answers my question will a fuel tank from a gas 250 fit on our diesels and would it be smart to use one that is used but has be cleaned out really good I found one for 20 bucks that I way I can move the truck to where it is going to sit for the winter
Old Sep 6, 2014 | 03:00 PM
whitetmw's Avatar
whitetmw
So long as its for the same wheel base you have. The Tanks are all the same which is why we modify ours with the Harpoon Mod. You will require another sending unit (for diesel) as the Gassers have the pump in the tank with the sending unit.
Old Sep 6, 2014 | 03:10 PM
bielaf's Avatar
bielaf
I have everything for the tank mine has a hole in it.... thanks for the reply
Old Sep 6, 2014 | 09:17 PM
raydav's Avatar
raydav
When I got my 84/460 the in-tank pump was in the process of eating it's filter screen. I replaced the pump with a piece of hose and put a pump on the frame. When I installed the diesel I did nothing more than pull the drain plug.
Old Sep 7, 2014 | 06:57 AM
tommyl's Avatar
tommyl
Rub the hole with a bar of soap!
Old Sep 7, 2014 | 07:39 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Newer 2011+ trucks have different sizes depending on the fuel type.
Old Sep 7, 2014 | 09:43 AM
bielaf's Avatar
bielaf
Just rub the bar of soap on it and let it sit nothing else?
F100trauma
Jul 25, 2017 07:21 AM
4x41977
Nov 15, 2013 09:44 PM
Flat_Ford
Oct 9, 2010 08:00 AM
Jesters Court
Jan 4, 2010 08:50 PM
kamac
28
Nov 17, 2003 09:23 PM
