Injector Circuit High code????
Old Sep 4, 2014 | 04:32 PM
Gothere's Avatar
Gothere
Help,
I just got a code on my 2004 F-250 6.0, P0265, which came out to be a Cylinder 2 Injector Circuit High. Did some searching and found the probable cause to be a Miswired connector or harness…
Ran the truck up on a camping trip about 125 miles, no issues, then some back roads, then on day 2 started it in the morning and check engine light came on associated with a little rough running.
Ran the truck home, another 125 miles, engine would shudder a little in a certain power band, then smooth out, no smoke and engine temp was perfect…
Haven't taken it to a mechanic yet, just wanted to research to see if anyone had any ideas/advice???
Thanks in advance for any info,
Ben
Old Sep 4, 2014 | 04:41 PM
9228.bobcat's Avatar
9228.bobcat
Possible coil on injector.
Old Sep 4, 2014 | 04:46 PM
Gothere's Avatar
Gothere
Thanks for the reply,
I'm new to all this diesel, first diesel engine for me, I'm guessing that the coil on injector is similar to the coil on plug of a gas engine?
How hard is the fix, just replacing the COI or more to it than that?
Thanks
Old Sep 4, 2014 | 04:57 PM
9228.bobcat
Need to do a power balance test with a ids or something equivalent. Might want to unplug the # 2 injector and see if it changes idle. If it is the coil, need to change the whole injector
Old Sep 4, 2014 | 05:06 PM
Gothere's Avatar
Gothere
OK, sounds like its going to the mechanic, worst case if it is the injector, how involved, and is it pricey???
Thanks again,
Old Sep 4, 2014 | 05:13 PM
9228.bobcat
About $250 for the injector and labor. Whatever they charge for that. Not bad of a job.
Old Sep 4, 2014 | 05:25 PM
Gothere's Avatar
Gothere
Well, not too bad, I was fearing in excess of $500, just bought this truck from a private seller and now I'm thinking it might be a lemon…Hope I'm wrong. Anyway thanks again for the info…
Old Sep 4, 2014 | 05:28 PM
9228.bobcat
Yea the labor will probably push it over that $500 mark.
Maleficent
Oct 19, 2017 08:45 AM
mkingz
Dec 16, 2015 03:46 PM
78fourby4f250
1997 - 2003 F150
Jul 8, 2015 10:49 AM
Corey2001
Feb 24, 2014 05:43 PM
KansasFlyer
Oct 31, 2010 04:31 PM
