Dash pad removal?
Old Sep 3, 2014 | 01:04 PM
forager's Avatar
forager
Dash pad removal?
1968 F250 Camper Special
390
C6
I've been considering stereo/speaker configurations for a while. I'm trying to avoid cutting holes in the doors or cluttering the floor space with boxes.
Recently, I found a stereo speaker that purports to replace the original speaker. I'm assuming that you have to remove the dash pad to uninstall/install the speaker(s). Is that so?
If so, how involved is the removal of the pad? There doesn't appear to be any way to remove the old speaker from below. Any thoughts or cautionary remarks?
Old Sep 3, 2014 | 01:14 PM
hillcountryflt's Avatar
hillcountryflt
Dash pad removal is a hand scratcher. You have a series of nuts to remove under the windshield/against the firewall and some nuts in each corner and a couple towards the part of the dashpad facing the driver/passenger.
However, the speaker would have to be removed from underneath. The dashpad simply covers a metal dashboard.
Old Sep 3, 2014 | 07:44 PM
Binkowski's Avatar
Binkowski
Radio and glove box
I got my speaker out by removing the radio and the glove box. I recall having to disconnect one of the vent tubes for the defrost too.
An excellent opportunity to clean up what's in the glove box. I agree, a hand scratcher so don't be afraid to wear a good fitting set of mechanics gloves.
Old Sep 3, 2014 | 08:03 PM
forager's Avatar
forager
Thanks, Hilcountryfit and Binkowski. I'll check it out.
Old Sep 3, 2014 | 08:11 PM
quinletc's Avatar
quinletc
I've got the page in the shop manual, but I can't figure out how to get the PDF page posted on here. If you have a manual, it's page 35-31-1.
Old Sep 4, 2014 | 07:02 PM
sandman2102's Avatar
sandman2102
Speaker removal is easy.....pull the radio....look thru the hole where the radio was and you will see the bracket that holds the speaker in. That bracet has a screw in the front that attaches the bracket to the dash. Remove that screw, lower the bracket in the front and push up in the back by the firewall and the bracket and speaker will release from the indents in the firewall. Unplug the speaker and you are done.
Old Sep 4, 2014 | 07:34 PM
gangstakr's Avatar
gangstakr
Very good answer, Dash pad removal not necessary. If it is unmolested, if it is, then all bets are off.
phaffy12
Aug 23, 2024 02:23 PM
ToughestTruckBuilt
Jul 17, 2009 12:37 PM
Bookman
Dec 10, 2008 07:14 PM
F100 Cobra
Apr 7, 2007 07:56 PM
mbrownone
Paint & Bodywork
Jan 17, 2007 08:06 PM
