Carter YFA identification
Old Sep 2, 2014 | 04:44 PM
billygoat's Avatar
billygoat
Need some guidance...
I've searched the WWW and could not find an answer...
I have a 1974 F250 4.9l with a carter carburetor. My truck is spewing out thick black smoke (worse than my diesel!). Plugs are correct motorcraft gapped at .044". I have it timed at 10 BTDC. The previous owner took the carb apart and attempted to clean it, however, did not rebuild it and/or may have not put it back together correctly. I am trying to identify which carb I have, however, the numbers are right on the casting seam (?) and appear to be 60640, or 06640, or something similar (a search came back with nothing) It does have 6-2228 stamped on the opposite side. I believe it has a manual choke and does not have a dash pod. With so many model numbers, I have a few questions:
1. Which carter carb is the right one for my truck (or range of model numbers)?
2. Which carter carb, if any, works best for my stock truck?
I want to ensure that I order the correct rebuild kit for the one I have, or look at the option of picking up the correct carb (or better) for my truck.
Thanks for all the knowledge shared!!!
Old Sep 2, 2014 | 06:05 PM
fmc400's Avatar
fmc400
MSEE
Someone can correct me if I'm wrong, but the last number you listed should be the list number. A real parts store (like Napa) will be able to cross-reference that in the books. Carters have them stamped in the cast, vs. a separate tag like Motorcrafts.
Old Sep 3, 2014 | 08:49 AM
1986F150six's Avatar
1986F150six
Carter manufactured carburetors for Motorcraft. Motorcraft put a tag on the carburetors, but quite often, this has been removed. The Carter identification number is stamped into the body.
There is a business called Mike's Carburetor Parts which has an excellent reputation and offers technical assistance. Also, their parts are manufactured in the good old USA!!
Here is a link:
http://www.carburetor-parts.com/
Old Sep 4, 2014 | 12:43 AM
billygoat's Avatar
billygoat
Here is a link:
Welcome to Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store
Thanks! It looks like one of the stock carb options was the YF 7051s (there are a few other carter numbers that will work as well)
Old Sep 5, 2014 | 12:27 PM
billygoat's Avatar
billygoat
I found these other two websites that were helpful.
THE CARBURETOR SHOP / TRUCK CARBURETOR REPAIR KITS F Applications
O.E.M Carburetor Catalog Ford, Mercury Trucks
I currently have the Carter YF 6646S (Motorcraft tag D4TE-ACA), which also has 6-2228 on the casing.
It appears that I should have either the 6532S or the 7005S (since my truck is 3spd, no A/C). Not sure at this point what the difference is between the three carbs mentioned.
The 7002S and the 7006S may work as well.
lazzarruss
15
Oct 30, 2013 08:59 PM
nuwave
May 12, 2007 03:06 PM
MikeMc100
Jun 13, 2006 06:15 PM
kooper909
Jun 1, 2005 07:23 PM
Derrick1972
Jan 26, 2004 01:22 PM
