Carb ID
Old Jun 10, 2006 | 07:55 AM
MikeMc100's Avatar
MikeMc100
Carb ID
I've looked around quite abit but can't find what i'm looking for. I'd like to know what all the numbers mean for the Motocraft Carb on my 74/75(not sure, reg says 75, parts say 74). Heres what I found on the tag:
D4TE JA
B4H 22
any help would be apreciated.
Old Jun 10, 2006 | 09:40 PM
Ford_Six's Avatar
Ford_Six
Sometimes a design carried over for several years, so casting numbers and tag numbers may be from previous years.
There should be a number on the side of the carb, behind the accelerator pump rod, with a circle/star around it. The number will be something like 1.21, that is the size of the venturis in the carb. Cross that number over using the chart in the top post in this forum to find the size of the carb in cfm.
The numbers on the tag are all you need to get a rebuild kit for the carb.
Old Jun 11, 2006 | 12:56 PM
subford's Avatar
subford
D4TE JA
B4H 22
D4 = 1974
D4TE = TAG NUMBER PREFIX
JA = SUFFIX
D4TE JA is the IDENTIFICATION number and crosses to D4TZ-9510-JA and was replaced by D4PZ-9510-BG.
Gasket Set = D4AZ-9502-A
Tune-Up Set = D4AZ-9A586-A
Repair Kit = None
Parts List = 30J
B4H 22
B= Design Change
4 = Year of Mfg. = 1974
H = Month of Mfg. = Aug.
22 = Day of Mfg. = 22
Old Jun 13, 2006 | 06:15 PM
MikeMc100's Avatar
MikeMc100
thanks...now i need to figure out if i want to redo it or replace it...seems like a 4bl would be much nicer on the 360
74 F350 SCS
Jan 16, 2013 11:31 AM
cnowlin06
Aug 28, 2012 03:02 AM
Dwinn
Aug 7, 2012 07:12 AM
9d4
Oct 25, 2009 11:00 AM
crewcab74
Mar 7, 2001 11:48 AM
