Source for PCV hose
Old Sep 1, 2014 | 06:07 PM
alchemist1's Avatar
alchemist1
Source for PCV hose
On my 74F100 and not quite the original motor, I'm looking for a molded rubber hose for my PCV valve, connecting the valve to the carburetor base plate. The only hitches are:
1. I have a 67 390 engine (from a Fairlane GT)
2. My carb is an Edelbrock 14063.
3. I use a year/application correct PCV valve for the 67 Fairlane, which comes straight up (doesn't make a 90 degree). I feel that is what should be kept for the engine.
The rubber hose would ideally have two 90 degree bends near each connection. Any ideas?
Old Sep 1, 2014 | 06:17 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Get a piece of 3/8" steel brake line. Bend it into the shape you want and use a couple of short pieces of 3/8" hose to connect the steel line to the carb and PCV valve, that's what I did with mine.
If you want to do it really right, find a shop that can roll beads into the ends of the line. Or you could bend the line then send it to Inline Tube and have them duplicate it with the proper beads.
Old Sep 1, 2014 | 07:14 PM
fmc400's Avatar
fmc400
MSEE
2x I've done that, and they do excellent work.
Old Sep 1, 2014 | 08:01 PM
alchemist1's Avatar
alchemist1
Great looking pic Mike. Mine doesn't really have the need for complicated bends. Just two simple 90 degree ones. How's the best way to bend steel tubing?
Old Sep 1, 2014 | 08:42 PM
blackjack33's Avatar
blackjack33
Buy a tubing bender and DIY.
Here's a LINK to a cheapie. I'm sure that'd last through two ninties.
Old Sep 1, 2014 | 08:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks.
The tool I used was real similar to the one in blackjack33's link.
Old Sep 1, 2014 | 09:06 PM
JWC 3's Avatar
JWC 3
Copper tube works fine also . Easier to bend by hand . Just a thought ....
Old Sep 4, 2014 | 11:47 AM
alchemist1's Avatar
alchemist1
are you sure about 3/8" steel brake line? That diameter seems small to me...
Old Sep 4, 2014 | 11:59 AM
fmc400's Avatar
fmc400
MSEE
3/8-inch is pretty common but I have seen 1/2-inch in some applications. Ultimately it depends on the intake port and the PCV valve.
Old Sep 4, 2014 | 03:00 PM
mikeo0o0o0's Avatar
mikeo0o0o0
3/8" is what I used, that's whats in the picture.
Dorman makes a whole series of PCV elbows. Maybe you could find a couple that would work. Here's one example, they have quite a few different versions, some with the same ID on both ends. Others, like the one pictured, have a different ID on each end.
Binkowski
Jul 17, 2017 08:20 AM
dsrtjeeper
Oct 15, 2011 09:13 AM
Pinzer
Modular V10 (6.8l)
Jan 19, 2010 10:30 PM
luke-gr
May 2, 2007 03:20 AM
67owner
19
Jan 30, 2007 03:59 PM
