pcv hose
Old Mar 3, 2014 | 03:10 PM
Binkowski's Avatar
Binkowski
pcv hose
Hi,
What are you all using for the pcv hose? To connect the pcv valve to the base of the carb. I am not worried about reproducing anything and am really not interested in a $23 hose. But I do need a reinforced hose so it won't collapse. The parts guys at the local stores seem confused, and heater hose just aint getting the job done.
In my case its a 360 with the stock two barrel carb.
thanks
Old Mar 3, 2014 | 04:25 PM
HIO Silver's Avatar
HIO Silver
'still using the OEM hose... it doesn't have very much vacuum as to warrant a reinforced hose IMO. And if it is collapsing, then the PCV is stuck or the hose is plugged.
Old Mar 3, 2014 | 04:31 PM
jowilker's Avatar
jowilker
I use a formed hose that I bought a few years back, and I don't recall where. What issues are you having with the heater hose? The vac. shouldn't be that great.
John
Old Mar 3, 2014 | 04:41 PM
Binkowski's Avatar
Binkowski
Hmm,
well the heater hose is collapsing. PCV valve itself seems to be ok. It rattles a bit after wiping it off. Doesn't appear to be stuck or all gunked up. I was looking at getting a new gromet for the passenger side valve cover where the pcv valve goes, as it seems a bit loose.
Did a new search and am now finding Gates hose rated for gas, oil, and emissions...guess I can try that.
Is there a way to test the pcv valve? What would be causing too much suction/compression?
thank you
Old Mar 3, 2014 | 07:32 PM
70-360fe's Avatar
70-360fe
Originally Posted by Binkowski
Hmm,
thank you
Just replaced mine, gas line from advance and works fine. (390 fe) If you get a new grommet check it before you leave the store. The one the computer selected was to small. Went in and got another one, worked but was real tight.
Kind of off subject but are you guys using for breather filter material. Advance use to sell a white round filter you could slip in from top of the pvc breather. They don't carry them any more.
Old Jul 15, 2017 | 01:58 AM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Emissions hose, and "high-pressure fuel injection" hose is better hose than regular gas line. it will have printing on it, to brag about it's rating. Avoid silicone and true-rubber hose for this application. Hot-oil eats rubber, and softens silicone.
Old Jul 15, 2017 | 07:24 AM
orich's Avatar
orich
2x with the EMISSION hose or go with the OEM one as look how long it lasted,
It's a thick hard formed oil resistant hose.
Stay a way from any soft rubber or plastic hose as it will collapse when it get hot after say a hour of driving on warm days.
The PCV hose & valve cover grommet all needs to be in good working order system to suck all the moisture out of the engine. It the VC PCV is loose split it won't suck out all the moisture as it was designed for.
Also if your not running a thermostat or one to low of temp you'll get a milky white formation build up in the valve cover in the winter months.
Orich
Old Jul 17, 2017 | 08:20 AM
Red69's Avatar
Red69
You can get push-lock hose by the foot at most parts stores. It is oil resistant and rated up to 200psi so it shouldn't collapse. I believe 3/8" is the size you need. This type hose is good for oil lines and transmission coolers also.
Deagle12
Modular V10 (6.8l)
25
Apr 14, 2023 09:39 PM
Jay Is Jay
May 28, 2017 06:02 PM
Jbrown8988
Feb 1, 2010 09:02 AM
Faithful Old Road Dog
Modular V10 (6.8l)
Aug 20, 2009 02:06 AM
brian.taylor
17
Apr 8, 2007 12:59 AM
