Exhaust Manifold
Old Aug 29, 2014 | 10:36 PM
coreyoliseffect's Avatar
coreyoliseffect
Exhaust Manifold
Please forgive me if this has already been answered.
Looks like I have an exhaust leak. Has anyone else ran into this?
EDIT: It appears that hole should actually be a metal tip. I recall hearing the sound of something metal falling and hitting while I was driving. What is the hole/tip?
Does anyone have any suggestions on a replacement?
RockAuto.com shows this as a replacement:
More Information for DORMAN 674943
Old Aug 29, 2014 | 10:47 PM
Money-Pit's Avatar
Money-Pit
Is it threaded? Put an EGT probe back in there to plug the hole.
Old Aug 29, 2014 | 10:50 PM
coreyoliseffect
It doesn't appear to be. The Dorman replacement has a metal nipple where the hole is on mine. Possibly for a probe like you said?
Old Aug 29, 2014 | 10:52 PM
Rellick's Avatar
Rellick
Do you have any gauges?
Looks like a hole for an EGT sensor. An aftermarket gauge, you have to drill a hole and put a temperature probe in it.
https://www.google.com/search?q=EGT+probe
edit: Never mind.
Old Aug 29, 2014 | 10:53 PM
coreyoliseffect
I do not have any gauges, however, there is a might fine chance that the previous owner did.
Given that I don't have gauges is it worth it to put a probe in it?
Not to mention that the manifold looks really rusty anyway.
Old Aug 29, 2014 | 10:59 PM
Rellick's Avatar
Rellick
get some.
gauges are a must.
The nipple on the dorman is for the EBP tube (top side, towards front).
Old Aug 29, 2014 | 11:05 PM
coreyoliseffect
get some.
gauges are a must.
So after looking at Advance; there is another Dorman part that does not appear to have the EBP fitting. Is there not an EBP sensor from the factory?
Old Aug 29, 2014 | 11:10 PM
Rellick's Avatar
Rellick
EBP was factory, but they disabled it for the 03-early 04, so I suppose it's possible for them to make one with out the hole. Makes way less sense to do it that way though. You could be looking at the underside, but probably the passenger side.
Old Aug 29, 2014 | 11:13 PM
coreyoliseffect
EBP was factory, but they disabled it for the 03-early 04, so I suppose it's possible for them to make one with out the hole. Makes it less sense that way though. You could be looking at the underside, but probably the passenger side.
Yea, the pics on Advance seemed to not have side that should have the EGP sensor.
The pic that took was from underneath and on the driver's side.
Old Aug 29, 2014 | 11:50 PM
78fordman's Avatar
78fordman
Just tap and plug the hole.
Old Sep 3, 2014 | 10:03 AM
Indslpwr04's Avatar
Indslpwr04
Thats the exact same spot i put my EGT prob. I bet it loosend up and the unhooked prob fell out. See if its tapped. If it is put a plug in it or put an egt guage in. mine is pretty rusty and crusty right now. It may not last much longer.
Old Sep 3, 2014 | 08:57 PM
BryanStein's Avatar
BryanStein
Looks like an EGT port or a EBP port. However, my EBP port is on the front of the drivers side. I don't know if they move the EBP port on various models.
It should be tapped. If so, find a plug to fit. If the threads are stripped (if the EGT probe fell out) retap a tad larger.
And get some gages. If you have an android device, spend $25 and get the Torque Pro app ($5) and a good OBDII Bluetooth reader ($20 off fleabay). it'll be the best $25 you'll spend this decade. I invested this $25 with the intent of upgrading when needed. The app is so powerful, I don't think I'll ever need to upgrade.
rvayda
Apr 7, 2016 09:39 AM
tractoman
Sep 21, 2015 07:43 PM
cable666guy
Aug 27, 2007 05:30 PM
5.4AZ4X4
Exhaust Systems
Aug 4, 2004 09:00 AM
shawn h
Nov 24, 2003 06:00 PM
