egt gauge install
Old Aug 3, 2007 | 10:16 AM
cable666guy's Avatar
cable666guy
egt gauge install
there is a hard line tapped into my left exhaust manifold. is this what the ecm/pcm uses for egt, and if so is there a way for me to tap into this for an aftermaret egt gauge? I'm not crazy about tapping a hole in there w/o removing it.
Old Aug 3, 2007 | 01:40 PM
blackhat620's Avatar
blackhat620
The PCM does not monitor EGT, if the hard line you are talking about is toward the front of the left hand exhaust manifold, it is for the EP sensor and no do not tap into it.
It is not a problem to drill and tap the exhaust manifold to install your A/M EGT probe.
Old Aug 3, 2007 | 02:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Everyone does it...driver's side manifold and towards the rear. Only place you can get a drill easily anyway. If you are afraid of shavings, after you drill the hole, start truck and let shavings blow out the hole. Be SURE you drill the correct size hole!!!! Oh yeah, buy a new, good tap!
Old Aug 3, 2007 | 06:22 PM
Dieselmanor's Avatar
Dieselmanor
FTE Sponsor
Gauge Install
Try this: http://www.dieselmanor.com/diy/PSD3-gauge/PSD60gauge-p1.htm
It should help you with the tapping and any other question regarding gauge installs.
Old Aug 25, 2007 | 09:01 PM
cable666guy
I know this is late in coming, but thanks for the replys.
David, that pictorial was particularly helpful, really nice!
Old Aug 25, 2007 | 09:11 PM
LvTitan's Avatar
LvTitan
i actually drilled my passenger side near the rear, and you can drill the hole with the engine idling, this will keep the shavings outside the manifold.
Old Aug 27, 2007 | 05:30 PM
Dieselmanor
FTE Sponsor
You're very welcome. I know that the pictures help many people. That's what they're there for.
Enomra
Oct 15, 2014 05:26 PM
ljfen
Feb 20, 2013 11:41 AM
AzPete
Jan 8, 2013 05:08 PM
Sparkplugless
May 29, 2009 01:31 AM
Gcourville
Mar 13, 2004 05:17 PM
