need alittle ignition switch help please
Old Aug 25, 2014 | 10:17 PM
omni's Avatar
omni
My ignition switch is getting pretty hard to turn, when you start it I have to pull it back to the on position it doesn't spring back on its own, some times I can pull the key out in the on position. would that be the tumbler assembly?
Old Aug 26, 2014 | 08:40 AM
Phy's Avatar
Phy
If you can pull the key out in the run position, that sounds like a bad key cylinder to me...
Old Aug 27, 2014 | 02:27 AM
omni's Avatar
omni
Thanks I'll change it out
NewEnglander
1978 - 1996 Big Bronco
17
Apr 16, 2012 11:46 PM
66F100Again
Dec 9, 2006 05:41 PM
Sqeejo12000
Jun 4, 2005 10:51 PM
orangedbowl
May 10, 2005 11:09 PM
