You ideally want the engine at normal operating temperature, so two minutes could've been not enough. But, the readings are consistent and that's really what you're going for. They're not as high as I would like them to be but it seems like the engine is just a little aged. Is it completely stock? Are you noticing a lack of power?
That, and the carb butterflies have to be full throttle wide open. All spark plugs removed. Fully warmed up, half hour at highway speed? Fully charged battery, good serviceable starter running at crank RPM spec. Dry test, then wet test, avg of the highest of at least two runs per cylinder, etc.
Compression test is a bit more complicated than it seems for accurate result. Those numbers don't look too bad considering. Mentioned in another thread, a vacuum gauge connected to manifold will indicate engine compression indirectly, and a whole lot more, with a lot less hassle. If engine draws 18, 19 or 20 inches steady then the compression is fine. A proper compression test itself is awful hard on the starter and battery imo.
It's stock and it's a project and it's not licenced for the road yet but I've driven it around the neighborhood a few times. I've got it all tuned up and it runs pretty good. Starts right up, idles good after warm up and revs up okay with no hesitation but when I drove it will fart at the carb a bit if I try anything beyond 1/2 pedal acceleration. Plan is body work and paint the exterior first. Phase two will be replace the tired drivetrain.
The last thing you want to do is make your truck look pretty before you can even reliably drive the thing.
My book is telling me either 9.5 or 10.5 for the 390 depending on your engine in 1968, but I have a feeling that is for the car engine. Why was the truck engine made so inefficient?
I don't feel comfortable saying this to you, but I think 100 psi indicates a worn-out motor. Probably rings/cylinders; it it were valves the numbers would not be so consistent. A wet test might confirm my opinion. My wheezy 352 is 130 across and should be 150+ the experts tell me.
Eric
... I think 100 psi indicates a worn-out motor ... My wheezy 352 is 130 across and should be 150+ the experts tell me. Eric
That's true but only if the compression test was done "by the book" ; and those are accurate numbers. Nothing against the OP, but it doesn't sound like it, would make sense to test more carefully before condemning the motor. Jus' Sayin'.
